It is currently Sep Fri 17, 2021 8:47 am
 Post subject: Canadian Westinghouse Model 275 Capacitor ID
PostPosted: Jun Wed 16, 2021 2:59 am
I have a schematic that is hard to read. If anyone knows what the value of the capacitor labelled C44 on this set, ID appreciate the help. It wasn't legible on the cap either.
Thanks.
 Post subject: Re: Canadian Westinghouse Model 275 Capacitor ID
PostPosted: Jun Wed 16, 2021 3:16 am
C44 .035µF (microfarad)
West....pdf [1.24 MiB]
Downloaded 22 times
PostPosted: Jun Wed 16, 2021 3:35 am
It appears that the 275 is very similar to the 175, at least about the tone capacitors.
The value for C44 appears to be 0.035uF. This clearer scan also shows that the nearby ground connects to a shield on one of the wires to the control, not to C44!
No doubt 0.033uF will be close enough. Might be good to use a 1kV or higher part, or a safety agency approved Class X or Y capacitor.
https://www.rfcafe.com/references/radio ... y-1936.jpg
Ted
It's interesting that the ARF site provided no warning about Greg's post.
The scan I found of the exact same schematic was not clear enough to be sure of the C44 value.
PostPosted: Jun Wed 16, 2021 11:47 am
Thank you VERY much for the information gentlemen. Much appreciated!
PostPosted: Jun Sat 19, 2021 12:19 pm
I have finished the work on this radio. If you wish, you can see it at:
https://www.youtube.com/watch?v=GjlEr8W1hVA
Thanks again for the help.
Post New Topic Post Reply  [ 5 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 14 guests
