It is currently Dec Thu 02, 2021 5:10 pm
 Post subject: this the correct of replacing this type of filter capacitor?
PostPosted: Sep Tue 28, 2021 8:16 am
i got a very late tube radio that i've replaced the filter capacitor. anyways its an external grounding can where all 3 lugs go to a different ground trace. ive replaced both values to their respective positive lugs and sent each to a different ground trace and then from both them negatives i ran 2 jumper wires to the 3rd ground trace. so i think i got it correct but just wanna double check here first just in case im about to burn the house down XD.
 Post subject: Re: this the correct of replacing this type of filter capaci
PostPosted: Sep Tue 28, 2021 9:05 am
if i understand you correctly the jumpers go to ground, it looks to me that one trace is clearly marked POSITIVE +. dont know what you have there but dont you think it might have been easier and neater to restuff the old can and reinstall it? but i do see what you are saying,but that positive + is a bit baffling. it looks like those all tie together at any rate. im not too jazzed with the jumpers being uninsulated.
PostPosted: Sep Tue 28, 2021 9:10 am
That looks correct.
Many miss the fact that single side boards use the can as a jumper between grounds.
Personally, I'd have put the jumpers on the top side. Just an OCD thing on my part. ;)
Scott.
PostPosted: Sep Tue 28, 2021 1:50 pm
Electrically OK; I would have slipped some spaghetti tubing over the bare wires to minimize the chance of a short.
PostPosted: Sep Wed 29, 2021 9:13 pm
If you haven't plugged it in to test yet, I would recommend you build a dim bulb tester.
A simple design is to cut one leg of a cheap two-prong extension cord.
If it's a polarized cord, choose the hot side, narrow blade side.
Install a lamp holder and a 40 Watt incandescent bulb (old type) or 60 Watt.
Then plug your radio into that cord to power it up. Bulb burns bright, something ain't right.
Burl Ives, RIP, oldtimer.
[:l>)
Post New Topic Post Reply  [ 5 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: lorenz200w, Paul Dietenberger, philcophanatic and 10 guests
