It is currently May Sat 30, 2020 10:29 pm
 Post subject: All-American Constant B Battery Eliminator
PostPosted: Feb Tue 10, 2009 5:36 am
This is a Type A1. It fails the dim bulb test after 2-3 minutes, I have downloaded the schematic but can't see the cap values or fully understand the drawing. Looks like 7 caps but don't understand the one for b-. When the tube is removed the dim bulb looks ok. Thanks, Bill
PostPosted: Feb Tue 10, 2009 5:52 am
This is a pretty standard BH circuit.
All condensers are paper, all referenced to B-.
The condensers at the plates of the BH are RF snubbers.
.o1 and 600v will be adequate.
All of the other condensers were either 1 MFD or 2 MFD.
If you can find a bunch of 2 MFD @ 450v miniature electrolytics they will do the trick.
If not, the common 10 mfd units will suffice.
You will get longer life out of he BH tube if you keep the first filter condenser down to 2 MFD, though.
PostPosted: Feb Tue 10, 2009 7:12 am
Thanks, it makes a little more since. My drawing shows one long cap that seens to run pos to b-, not sure I understand part. Thanks, Bill Found this download on another sigut
Post New Topic Post Reply  [ 3 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: 1MohrRadio, Google [Bot], nash, Tom Albrecht and 15 guests
