It is currently Oct Sun 02, 2022 8:49 am
Post New Topic Post Reply  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: Spray over asbestos
PostPosted: Jul Wed 13, 2022 12:10 am
I have used the high heat spray paint in the past with no problems. Spraying from a distance is advised.
Jim
KE8GMW
I have flying monkeys and I know how to use them.
PostPosted: Aug Sat 13, 2022 8:02 am
Three options, leave it alone, paint it with a water based paint or glue (with a brush)so it soaks in, or glue aluminum over top of it. If you remove it, soak it with water first, put it in a plastic bag, and throw it in the garbage, then go to an auto parts store and pick up some exhaust gasket material as a substitute.
Regards
Arran
PostPosted: Aug Sun 28, 2022 2:55 pm
If the high-heat spray paint requires heat to cure, then use a heat gun on it. As far as the spray from the can or wind from heat gun causing a few airborne fibers, do it outside with a mask on. Then run the lawn blower to clear the radio and area.
Doneā€¦.
Post New Topic Post Reply  [ 23 posts ]  Moderator: Peter Go to page Previous  1, 2
