It is currently Jul Sat 20, 2019 12:27 am
 Post subject: bubbled veneer
PostPosted: Sep Mon 17, 2018 7:59 pm
What the heck have I done? I applied a new veneer to a Philco cathedral radio, using the "2 glue" method- applied wood glue to both pieces, let dry, then applied another coat and let dry. All went well (I thought) after I ironed the veneer onto the cabinet. Now I have bubbles EVERYWHERE. I mean they're all over the place..I've never seen this before. I'm going to pull it off and start over, but any thoughts what might have caused this so I don't do it again?
 Post subject: Re: bubbled veneer
PostPosted: Sep Mon 17, 2018 10:25 pm
What kind of glue?
Did you try reheating the bubbles to get them down?
PostPosted: Sep Mon 17, 2018 11:00 pm
I used Titebond brand wood glue. I applied it with a small brush, and I'm wondering if something could have been in the brush that contaminated the glue. I have had a bubble occasionally pop up, but nothing like this. I have ironed and ironed and haven't gotten rid of one bubble.
PostPosted: Sep Tue 18, 2018 2:39 am
I use a hard rubber roller to evenly apply glue on both surfaces, 2 layers of glue on top of each other after one and second had dried may be the problem. I would only use one layer of glue on each surface.
PostPosted: Sep Tue 18, 2018 3:27 pm
I agree with Fred. You would not need two layers of glue on each piece.
That would end up being too much glue. one thin coat is all I ever use as
it does not take a lot of glue to hold the veneer and wood together.
One thin coat:especially on the veneer because it can bleed through to the other side and then you have problems.
Dan in Calgary
PostPosted: Sep Tue 18, 2018 4:29 pm
Sounds like too much glue.
PostPosted: Sep Sat 22, 2018 11:01 am
Gluing each side is often only helpful if its a contact cement type of adhesive, but I'll caution that I have had bad results with contact cement for veneer eventually loosening up.
I have switched to the extra dark walnut tinted tightbond veneer glue (cold press not iron on) that I believe FStephenMasek originally recommended to me in a thread some time ago. Just one side needs a light even coating, press together, clamp/etc as needed and let sit.
Post New Topic Post Reply  [ 7 posts ]  Moderator: Peter
