Page 1 of 1
[ 6 posts ] |
Author |
radios2100
Post subject: Ideas on how to restore these missing pieces? Posted: Nov Sat 10, 2018 7:05 pm |
Member |
Joined: Oct Sat 18, 2014 8:16 pm Posts: 1621 Location: Galena, Ohio
Top |
Brett_Buck
Post subject: Re: Ideas on how to restore these missing pieces? Posted: Nov Sun 11, 2018 12:31 am |
Joined: Aug Wed 24, 2011 4:35 am Posts: 5359 Location: Sunnyvale CA
radios2100 wrote: I have a nice early Zenith, but it's missing a few pieces of trim that I'd really like to find a way to restore. Hoping one of you guys has some trick for restoring these without trying to track down an ultra rare replacement.
The good news is that one side has the original piece while the other side is missing it, so I was thinking maybe pop off the remaining one and create a mold, then use wood textured mold material to create the replacement. Obviously would need to then stain the replicated piece before gluing it to the cabinet.. The most obvious solution is to simply carve a new one from wood. This looks relatively simple by carving standards, and if you have a template to go by to lay it out, that's an hours work. No particular artistic ability would be required, you already know what it is supposed to look like. Might take a couple of tries, but that's sure what I would do. Brett
Top |
radios2100
Post subject: Re: Ideas on how to restore these missing pieces? Posted: Nov Sun 11, 2018 12:37 am |
Member |
Brett_Buck wrote: The most obvious solution is to simply carve a new one from wood. This looks relatively simple by carving standards, and if you have a template to go by to lay it out, that's an hours work. No particular artistic ability would be required, you already know what it is supposed to look like. Might take a couple of tries, but that's sure what I would do. Brett I don't think I'm experienced enough with carving to achieve that. I could probably make the side trim piece as it would just be a strip of wood I could take a router to match that pattern as closely as possible. The pedal piece on the front and the leg part are out of my league for wood carving though.
Top |
LBF ARSR
Post subject: Re: Ideas on how to restore these missing pieces? Posted: Nov Sun 11, 2018 1:19 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 365 Location: Sandhills of Nebraska, 69170
I have a Majestic Treasure Chest that was missing a lot of the trim accent pieces when I got it. I bought a epoxy mold making kit at Hobby Lobby that worked really well. My pieces were probably smaller than yours, but I had never tried anything like that before, and it turned out fine. I had to pry off a good piece, then made a mold from it. The coloring took a little trial and error, but eventually I got it pretty close. They have different dyes you can add to the epoxy.
Wasn't too expensive I don't think. Maybe worth a try?
Good luck, Travis
Top |
westcoastjohn
Post subject: Re: Ideas on how to restore these missing pieces? Posted: Nov Fri 23, 2018 5:10 am |
Member |
Joined: Dec Sat 24, 2011 9:17 pm Posts: 7146 Location: Vancouver Island, Canada
+!, I second the motion. Make a casting from plastic or epoxy, stained or painted to match. No, I haven't done this myself, but mean to try. A Packard Bell I have is missing one grill bar.
_________________ Watch the doughnut, not the hole. Burl Ives, RIP, oldtimer. [:l>)
Top |
madsowry
Post subject: Re: Ideas on how to restore these missing pieces? Posted: Dec Mon 10, 2018 3:50 am |
Joined: Feb Wed 15, 2017 11:49 pm Posts: 386 Location: Kingsville, OH 44048
I don't know if anyone is paying attention to this post anymore but if you look at my post of the Brunswick mod 22 restoration I had to carve a piece for the leg just like this one. It's amazing to me that these legs were square in all the fancy areas and 4 little carved pieces were glued on to make them fancy looking. It's not real hard to carve one of these pieces. Use basswood or poplar. They are solid and not hard to carve. With a small belt sander and xacto knife anyone can carve these especially since you have an original one to look at.
Top |
Page 1 of 1
[ 6 posts ] |
Moderator: Peter |
Users browsing this forum: voroush and 8 guests |
