It is currently Jan Sat 16, 2021 6:42 pm
 Post subject: Stuck knobs because of rusted screws
PostPosted: Dec Sun 02, 2018 6:34 pm
Hi All,
I'm struggling to remove the knobs on a Silvertone 4465, there's a little screw on each of them that are badly rusted and they don't want to move. What are you usually using to loosening them ?
I was thinking of using WD-40 but is it safe to use it on wooden knobs ?
Al.
 Post subject: Re: Stuck knobs because of rusted screws
PostPosted: Dec Sun 02, 2018 8:23 pm
WD-40 shouldn't attack wood at all, or really anything else. That would be the first thing I would try.
PostPosted: Dec Sun 02, 2018 8:45 pm
Thanks for the reply, and forgive my ignorance, those knobs was in fact in plastic :oops:
so WD-40 did a great job, only one left that is harder than the others.
Al.
PostPosted: Dec Sun 02, 2018 11:14 pm
I just guessed that the knob was wood, but no matter. If the harder one is still stuck on the shaft, I would orient the knob so the setscrew is facing up, then shoot some more WD-40 into it, and wait awhile, in order for it to penetrate.
PostPosted: Dec Sun 09, 2018 2:27 pm
Hey, if the WD 40 doesn’t do the trick, I like to use KROIL. This stuff is amazing.... works like WD40, it’s a penetrating oil and will not hut the plastic , or wood. Good luck :)
PostPosted: Dec Sun 09, 2018 3:22 pm
If you can heat the knob shaft up with soldering iron and get it hot, then try and pulling off.
