It is currently Feb Thu 20, 2020 4:00 pm
 Post subject: Paint Help! Barrior Coat on Plastic Knobs
PostPosted: Dec Sat 22, 2018 6:28 pm
Does anyone have any suggestions as to what to use as a barrio coat/cover coat on plastic knobs when trying to paint to match a case color?
The solvent in the colored paint I am using is attacking the plastic! Getting the colored paint to attach to the knob is not a problem, it's eating into the plastic is the issue!
I'm sure others have had this problem. Thanks for any suggestions!! Merry Christmas!
 Post subject: Re: Paint Help! Barrior Coat on Plastic Knobs
PostPosted: Dec Sat 22, 2018 6:45 pm
I use Max Meyer 1.880.2000 a one-pack etch primer in a rattle on plastic radios - never had a melting problem.
They market a 1K adhesion promoter (1.880.1600) for plastics - never tried it.
not a paint expert. Lol
PostPosted: Dec Sat 22, 2018 11:24 pm
There's also a 3M product for painting/priming plastic bumpers. Match-a-Color has some plastic paints as well, and may have a bonding primer for plastics. I recall seeing one for priming plastic wheel covers at NAPA.
Brian
PostPosted: Dec Sun 23, 2018 12:54 am
Fine sand the places where the paint attacked the plastic if regular sand paper won't work try wet sanding them.
Prime them with one of the above mentioned primers. Let the primer dry for a day to expel any solvents in the primer. Then you should be able to paint them with no problems.
Knowledge is useless unless you can share it. KA5OBI
PostPosted: Dec Sun 23, 2018 1:44 am
Thanks all for great suggestions!!
Post New Topic Post Reply  [ 5 posts ]  Moderator: Peter
