It is currently Jun Thu 27, 2019 9:50 am
 Post subject: 1937 Detrola 148E help: My Eve needs one of Adam's ribs!
PostPosted: Jan Fri 18, 2019 12:03 am
I need one of the ribs from a donor cabinet to make her whole again! I can't post an ad until I know the model number. What model is this? Can't seem to find any pics on the net without a model number. Is the back original?
Thanks, Steve
 Post subject: Re: Detrola help: My Eve needs one of Adam's ribs!
PostPosted: Jan Fri 18, 2019 1:06 am
1937 Detrola model 148E
It looks like the original (fragile) ply speaker grille bars have been replaced, or it was a factory improvement?
https://www.google.com/search?q=1937+De ... 52&bih=759
Dennis may know?
The heavier ones look good and should be easy for a woodworker to recreate one.
If you are unable to make one, remove the remaining one on the right/hand side. It should come-away by rocking back and forth. Mail it out, or take it to a woodshop... :)
PostPosted: Jan Fri 18, 2019 1:13 am
Greg,
I would have to doubt they're a replacement. Just an old radio back then. Making what looks like steam bent bars, is no easy task. I just looked harder at that photo page and there another is! A 148E on the second row of pics, right side of my screen! I hope to find an original, before having to make one. I've sent an email to Dennis, hoping he has an answer.
Steve
PostPosted: Jan Fri 18, 2019 1:25 am
If you are competent with a router, and you know how to spin a radius with a trammel, it wouldn't be too difficult to make a bench former (jig) for bending layers of birch ply - glued on top of each other.
My local guy can supply thicknesses of 0.4mm / 0.8mm / 1.2mm / 1.5mm / 2mm
PostPosted: Jan Fri 18, 2019 6:31 am
Well, I posted an ad. Hoping for the best, before having to make one....
PostPosted: Jan Fri 18, 2019 2:48 pm
Sorry I don't want to hijack this thread. I have this exact same radio, I've asked a few members in the past and never got a response. Mine has a replacement speaker and it sounds terrible and is not correct (yes, it has been re-capped). I know they used a Rola. Did they use, this identical speaker in any other Detrola models ? so I can keep my eyes open for one, or at least ask in the classifieds. I asked a few years ago, again, no response. I have a few Detrolas and the speakers are much larger. Yes,...your back is original, mine has one.
Bad form I know, sorry, carry on. :oops:
Tony
PostPosted: Jan Sat 19, 2019 2:38 am
Tony,
the 8" speaker - part number 3710 used in Detrola 147E
Photos: https://www.radiomuseum.org/r/detrola_147e.html
Schematic: https://americanradiohistory.com/hd2/ID ... e-0013.pdf
was also used in Truetone model D724
Photos: https://www.radiomuseum.org/r/western_au_d724.html
Schematic: http://www.nostalgiaair.org/Resources/892/M0023892.htm
Detrola 148E
Photos: https://www.radiomuseum.org/r/detrola_148e.html
oh... If you ask in the Electrical/Mechanical Repair and Restoration forum, someone may advise you on a suitable replacement.
PostPosted: Jan Sat 19, 2019 6:02 pm
Greg, I currently have 2 Detrola D724's. This is where things get STRANGE. The speakers in the D724's are 8" speakers. The 148 radio has a 6" speaker in there now. It is not original, there is no way a 8" speaker will fit in that location. The speaker mounting holes do not accommodate a 8" speaker. There is an original cardboard "backing" where the speaker goes (stapled in) and it has a 6" cutout. So,.....the schematic is in error as to the correct model of speaker used in the 148. Just to add, it looks like the model 147E is push-pull output using dual 42's and the 148 only uses a single 43 driver tube.
Tony
PostPosted: Jan Sat 26, 2019 1:38 am
Well, the radio arrived safe and sound! I have someone in the hobby who will be making me new ribs and then the cabinet will be off for a refinish. I also will be replacing the screws for the back. it has modern Phillips head screws with gold zinc plating on them. I'm guessing slot head screws with a dark finish on them will be right. Luckily for me, I do business with a plating company, so that'll be an easy fix, once I get the screws. Will post a thread, once restoration starts.
Steve
 Post subject: Re: 1937 Detrola 148E help: My Eve needs one of Adam's ribs
PostPosted: Jan Sat 26, 2019 2:09 pm
You might want to check on the phillips screw question. They were in very common industrial use for about 10 years already by the time this set was made.
PostPosted: Jan Sat 26, 2019 3:42 pm
Maybe Tony F can help with what his has???
The reason I suspect they are not original, is that they are zinc dichromate plated. Not a common occurrence in Radioland, in 1937, I have to believe.
PostPosted: Jan Sat 26, 2019 4:53 pm
Here is an original screw. It measures 1/8" wide by 1/2" long. It is slotted and dark brown . I'd imagine if there is any "slop" or wear in your original holes you might want to go with 5/8".
Tony
PostPosted: Jan Sun 27, 2019 7:15 am
Tony,
Sounds good. I’ll get some of those.
Steve
Post New Topic Post Reply  [ 13 posts ]  Moderator: Peter
Users browsing this forum: Alan Voorhees and 5 guests
