It is currently Jun Wed 26, 2019 7:42 pm
 Post subject: Adhering veneer
PostPosted: Jan Tue 29, 2019 1:48 am
Have some small areas of veneer that has lifted on edges. Would like to squirt glue under lifted piece and clamp down. Having problem diluting glue enough to use in my syringe. Glue(titebond) is water repellant so obviously cant be diluted with water. Tried small amount of acetone and glue kurdled. What should I use. Thanks
 Post subject: Re: Adhering veneer
PostPosted: Jan Tue 29, 2019 2:04 am
Titebond, Titebond II or Titebond IIIcan be thinned with water. I have done it several times.
PostPosted: Jan Tue 29, 2019 2:14 am
Thanks,Ill give it a shot
PostPosted: Jan Tue 29, 2019 9:24 am
It sometimes doesn't work :cry: Or not for long. Over the years dirt and polish gets in. Best to try folded fine grit paper and abrade a little and then blow out with a compressed air duster before applying the glue.
Gary
PostPosted: Jan Wed 30, 2019 3:42 am
+1 to Gary said. Definitely try to clean it out first.
Users browsing this forum: Tony F and 2 guests
