It is currently Dec Mon 09, 2019 8:34 am
 Post subject: Cleaning Bakelite Cabinets
PostPosted: Feb Mon 11, 2019 3:19 pm
What is the best way to clean smoke residue off Bakelite radio cabinets?
Thanks, Phil
 Post subject: Re: Cleaning Bakelite Cabinets
PostPosted: Feb Mon 11, 2019 3:23 pm
Dab some GoJo on a spot and see if that takes it off. Before you try anything harsh that might dull the finish. I think some of the bakelite in radio cabinets somehow deteriorates or oxidizes or something like that. Then when you wipe them down stuff comes off that resembles smoke residue but is apparently the material itself.
PostPosted: Feb Mon 11, 2019 4:49 pm
Novus 2 works well.
PostPosted: Feb Mon 11, 2019 5:24 pm
In some environs the surface of the bakelite decomposes or oxidizes. This is not necessarily a loss, as I have been able to bring back the finish to original looking by rubbing with Chrome Cleaner or Brasso (not the older formula's, but the new fine consistency formula's). A final treatment with automotive polish completes the process.
PostPosted: Feb Mon 11, 2019 5:49 pm
+1 to above comments by wazz, I agree with him completely. If you use anything harsh or abrasive, you may find a brown residue coming off which you might think is smoke, nicotine or dirt. In reality it may be the upper (smooth) layer of the bakelite itself.
I would advise an initial cleaning of any bakelite cabinet in warm soapy water using only liquid Dawn or some other similar mild product and a soft rag or sponge. Then let it dry and evaluate it to see if more aggressive methods are needed. In my experience, most Bakelite cabinets after an initial cleaning with liquid Dawn can be followed up with a couple of coats of traditional SC Johnson Furniture Paste Wax, followed by buffing with a soft cloth, with excellent results.
Poston
PostPosted: Feb Mon 11, 2019 7:23 pm
With bakelite I find its best to avoid using ANY cleaners on them unless its absolutely filthy. I generally use Meguier's cleaner caranuba car wax. That will usually remove most grime and also preserve the finish
PostPosted: Feb Mon 11, 2019 8:31 pm
Thanks to all, Dawn it is and then car polish/wax
PostPosted: Feb Tue 12, 2019 2:05 am
OK. Well with the Gojo I tried on several bakelites, it seemed to clean and also left a bit of a shine on the cabinet to boot. I am not sure that the shine will last a year or five though. I have had cases that were dull to begin with and nothing helped much. Although I don't suppose I tried wax but can't remember.
PostPosted: Feb Tue 12, 2019 2:57 am
I exclusively collect bakelite sets. I use the white soft soap ivory and then polish with the spray on car wax that comes in the red wine colored spray bottle.
below are a few examples.
steve
PostPosted: Feb Tue 12, 2019 6:49 am
Name brand please? I'd like to try it.
PostPosted: Feb Tue 12, 2019 6:00 pm
ok, i will look later.
big ice storm, schools closed, lots of time on my hands
steve
PostPosted: Feb Wed 13, 2019 3:33 am
steve
PostPosted: Feb Wed 13, 2019 4:49 am
Site Admin
Does it contain silicone?
PostPosted: Feb Wed 13, 2019 5:05 am
Yes, in a compound:
SDS for M66, Quick Detailer (21-141A): M6601
Ingredient: Polydimethylsiloxane
Chas
PostPosted: Feb Wed 13, 2019 5:13 am
thanks, that answers that.
the bottle was put back in the garage earlier today after its photo shoot.
steve
PostPosted: Feb Wed 13, 2019 7:53 am
So is there a downside because of the ingredient in it?
PostPosted: Feb Wed 13, 2019 3:17 pm
i would like to know this as well.
i've never experienced a problem. i've used it for years.
steve
PostPosted: Feb Wed 13, 2019 3:28 pm
I don't think the silicone has any adverse effect provided you don't want to paint the bakelite.
Nobody mentioned Metal Armor. I have used this on quite a few bakelite items with great success. It contains an extremely fine abrasive that polishes the surface of the bakelite. Even No. 7 auto polish works good. After the polishing, I use a coat of paste wax. Cleaning and waxing alone can't produce the shine from using a polish then wax. Bakelite knobs and escutcheons go into my vibratory tumbler which is crushed walnut shells and polishing rouge. They come out high gloss.
And a big thumbs up to Bob's mention of Meguier's cleaner caranuba car wax, the stuff is excellent, and yes, it does contain a fine clay in the wax to provide the cleaning action.
Disclaimer:
Test a small area with whatever you decide to use first. Some bakelite's are degraded to the point where you can no longer polish.
PostPosted: Feb Wed 13, 2019 3:54 pm
steve
Bob ?
PostPosted: Feb Wed 13, 2019 4:29 pm
Dutch Rabbit wrote:
Bob ?
Bobwilson1977
Post New Topic Post Reply  [ 25 posts ]  Moderator: Peter Go to page 1, 2  Next
