It is currently Oct Sun 20, 2019 1:22 pm
 Post subject: Help Cleaning 1956 V-M Tri-O-Matic
PostPosted: Feb Thu 28, 2019 8:34 pm
Hello all,
I've acquired this nice V-M player
to restore.
I have cleaned about 20% of whatever this brown gunk is
on the contact vinyl covering.
Usually, I start with soap/water, then de-greaser, and
that's all I need. This stuff is more resistant.
Obviously not water soluble and not ether alcohol soluble
as the de-greaser is. Even tried ammonia, no go.
I'm open to any good/safe suggestions ya'll have.
Hotwax
 Post subject: Re: Help Cleaning 1956 V-M Tri-O-Matic
PostPosted: Mar Fri 01, 2019 2:53 am
Try Westley's Bleche-White whitewall cleaner. I've yet to find something that stuff won't clean. Dont spray it directly though, or you'll get spotting.
PostPosted: Mar Fri 01, 2019 3:08 am
Site Admin
Naphtha (or Mineral Spirits, which is chemically similar). Most furniture restorers use it for cleaning as it removes oils and waxes, but won't hurt most finishes.
PostPosted: Mar Fri 01, 2019 5:15 am
I've had good results with Westley's Bleche-White as well. Give it a few minutes to work.
Ed
PostPosted: Mar Sat 02, 2019 9:34 pm
I tried the white-wall cleaner, and it had zero effect.
I'm going back to the soft toothbrush and dollar store
de-greaser.
Not the first time I've spent repeat sessions working at
cleaning this stuff off on 1950's record player cabinets.
Thanks for the input,
Hotwax
PostPosted: Mar Mon 04, 2019 2:34 am
Well, that's a first! Must be a stain (paint, rust, etc) rather dirt/grime/grease/nicotine, all of which dissolves instantly with Westley's.
PostPosted: Mar Mon 04, 2019 3:23 am
Whatever you use, you might try using 0000 steel wool in gentle circular motions. It might be more effective than the toothbrush. Test it on a small part of the bottom to make sure it does leave unwanted marks. Don’t scrub, just gently rub.
Ed
Post New Topic Post Reply  [ 7 posts ]  Moderator: Peter
