It is currently Jun Thu 20, 2019 4:02 am
 Post subject: Questions on gold trim of this Crosley
PostPosted: Mar Sun 17, 2019 1:31 am
Hi all,
Working on Cabinet of this Crosley 11-109. The gold trip has pitting and indented letters. It needs to be repainted. The bakelite is fine-
1. How do I get rid of the bumps and the pits on the trim?
2. What is the best way to paint the numbers that are inlayed and dark green or black?
The rest of the cabinet is in great shape if I can figure out the gold trim
Daryl
Daryl B. Presque Isle, Maine
 Post subject: Re: Questions on gold trim of this Crosley
PostPosted: Mar Sun 17, 2019 3:04 am
I had a GE clock radio that had gold trim around the clock with depressed numbers like that. Since the shiney plastic was toast anyway I sanded off the gold stuff that was there. sprayed it with the "number color" then after the numbers dried I filled the numbers with modeling clay and sprayed new metalic gold on the trim. after it dried a picked out the clay from the numbers. So I had the colored numbers and the gold trim as well.
Not quite original looking but I did not care it looks good anyway.
PostPosted: Mar Mon 18, 2019 12:15 am
Great idea. I wondered if an oil substance would work too- like Vaseline in the numbers so it would be easy to wipe away.
Daryl
PostPosted: Mar Mon 18, 2019 1:31 pm
Oil substances will make a mess it will seep where you don't want it.
it was easy to remove the clay with a tooth pick.
