It is currently Sep Thu 24, 2020 3:47 pm
 Post subject: Plastic restoration/ repair/ painting
PostPosted: Mar Wed 27, 2019 3:03 am
Hello everyone I’m new here and I’m looking for some suggestions. I received a customers Uniden Madison in the mail the other day and as expected he didn’t pack good and it was damaged. As finding a new face is near impossible I am going to try and repair it.
I ordered a plastic cement that has the consistency of water that will actually weld the plastic together as they called it. I have a few of the pieces I will be putting back in and bonding. Once that’s complete I will most likely use a bondo to fill then sand till I get it looking back to normal.
Now leaves me the repair color! How should I and what should I use as far as paint to work on plastic? I’m figuring I will need to try and match color best I can and spray entire outer bezel.
Any suggestions? Tips? Best paints to use?
 Post subject: Re: Plastic restoration/ repair/ painting
PostPosted: Mar Wed 27, 2019 10:40 am
Site Admin
This might help: https://antiqueradios.com/features/paint.html
PostPosted: Mar Wed 27, 2019 2:44 pm
Thank you this will be a huge help for me!
PostPosted: Mar Thu 28, 2019 5:11 pm
If it is conventional plastic that can be glued with conventional glues like Tenax and IPS #7, then, Testors plastic model paint comes in the small quantities needed and in a huge variety of colors, and it designed specifically for plastic.
Brett
PostPosted: Mar Sun 31, 2019 5:50 am
Great idea on the paint! I just ordered some and will give it a shot.
Thank you
Post New Topic Post Reply  [ 5 posts ]  Moderator: Peter
Users browsing this forum: Electronic Memory, forumuser and 3 guests
