It is currently Sep Sat 25, 2021 10:48 pm
 Post subject: Firestone 4-A-21X Cabinet Restoration
PostPosted: Dec Mon 24, 2018 12:51 am
The chassis restoration of this radio can be found here:
viewtopic.php?f=6&t=350754
I removed the bezel and cleaned inside and out of the cabinet. I then stripped it and wiped it down with acetone. It won't be till later next week till I get my new filler so it'll be a week before another posting. In the meantime I'll steam out as many dents as possible.
Crist
 Post subject: Re: Firestone 4-A-21X Cabinet Restoration
PostPosted: Dec Mon 24, 2018 5:01 pm
It is a very nice looking cabinet , and it should look good when you are done.
Dan in Calgary
PostPosted: Jul Sat 06, 2019 9:09 pm
OK, it's been awhile. I had to do 3 other projects that came up. Back to this one.
I then sanded down the cabinet with 220 grit and cleaned off the dust. I then applied Timber Mate Ebony as a grain filler to the top and the front face. After letting it dry overnight, I sanded the grain filler off. I then vacuumed and used a tack rag to clean the cabinet.
I'm in the process of applying several coats of sealer.
Crist
PostPosted: Jul Mon 08, 2019 3:54 am
Today I sanded down the sealer coats with 800 grit sandpaper. I then shot 1 coat of Semi-Gloss clear where the decals are located. This ensures that the area behind the decal stays clear and not "foggy" from sanding the sealer coats.
When dry I applied the decals. BTW, I got them Radio Daze. Worked perfectly.
Then I fogged on several coats of semi-gloss over the decals. I then sprayed on 5 coats of semi-gloss over the cabinet. I'll let it dry overnight. Then on to the trim.
Crist
PostPosted: Jul Mon 08, 2019 1:54 pm
That came out beautiful. I've used Radio Daze decals on a few radios. My first attempt didn't come out well because grown men don't read directions. Next I followed there directions to the letter and it was a breeze.
I love working on the small wood cabinets.
Freeman
PostPosted: Jul Mon 08, 2019 2:33 pm
Thanks. Small wooden cabinets are nice to work on, that's for sure.
Crist
PostPosted: Jul Mon 08, 2019 11:53 pm
I sanded down the cabinet and masked it off for the trim. I then shot the trim.
Crist
PostPosted: Jul Tue 09, 2019 4:17 am
After some semi-gloss clear.
Crist
PostPosted: Jul Thu 11, 2019 1:58 am
Today I wet sanded down the front and the top. I used 000 steel wool everywhere else. I painted the speaker grille, knob holes, and the dial face cutouts with some satin black lacquer.
Then 4 coats of Buffcote lacquer for the final top coats.
Crist
PostPosted: Jul Sat 20, 2019 2:45 am
Gorgeous!
PostPosted: Jul Sat 20, 2019 8:44 pm
That's looks great , I had done one like that years ago, nice lookin radio.
PostPosted: Jul Mon 22, 2019 10:08 pm
Very very nice work. Take a bow.
Freeman
PostPosted: Jul Tue 23, 2019 12:56 am
Thanks for the nice comments guys.
Crist
Post New Topic Post Reply  [ 13 posts ]  Moderator: Peter
