It is currently Mar Sun 29, 2020 3:54 pm
 Post subject: Repaint raises letters on zenith trans oceanic b600
PostPosted: Nov Mon 18, 2019 6:35 pm
Best way to repaint the raised letters on my zenith transoceanic b600 wave magnet antenna?
 Post subject: Re: Repaint raises letters on zenith trans oceanic b600
PostPosted: Nov Thu 21, 2019 4:59 pm
I’ve done a few of them and I use white acrylic from the hobby store and a real tiny brush because it’s water base and easy to clean up mistakes. You want a very small amount of paint on the brush. I use a roller now. Found it at the local hardware store of hobby store. A piece of tape on it. Paint the tape, but not a lot. Do one letter at a time and work your way across. You want a thin coat so it doesn’t run down the side of each letter. Let them dry. I think I had to go over it 3 or 4 times. The letters are slightly higher than the frame, but not much. If you make a mistake and you will, clean right away with a damp cloth.
Hope this helps.
Freeman
PostPosted: Nov Fri 22, 2019 5:31 am
Thanks I’m gonna try that out
Post New Topic Post Reply  [ 3 posts ]  Moderator: Peter
Users browsing this forum: Ed Engelken and 1 guest
