It is currently Feb Tue 25, 2020 10:47 am
 Post subject: ZENITH SHUTTER DIAL SCALE RESTORATION
PostPosted: Dec Thu 19, 2019 5:37 am
I wanting to make my restoration of my zenith 15u270 as nice as possible and in doing so I'm getting the chassis to look as nice as I can and preform as nice as i can. Many times the dial scales are messed up in some way and this one was no acception. It was scraped, rusted a little and just did not look good. The decals are available at radio daze. This is not the first one, I have done several already. They can be a little difficult to put on and get straight but well worth the time. I will show some pictures of my process, first you have to strip off old paint, sand smooth, spray on primer, spray on black lacqer paint, apply decal, apply decal set solution, clear coat 3 or 4 times, tinted in between clear coats to give the lettering an aged (PITINA) look instead of pure white. That's it, lots of steps but now you have a perfect aged looking dial scale.
File comment: Would you put that back on and display your radio (NO)
File comment: Stripped and primed with an auto primmer for small jobs. Any auto paint supply should carry this in a spray can.
File comment: Mohawk carry's a good satin black in spray can
File comment: Dial scale Decal is cut out bottom right.
File comment: Making a relief cut so decal can fall down in corner.
File comment: Notice right half I used solvaset to melt down the decal into the paint. Its helps a lot but you don't have to use it. Better if you do use it. Left side you notice whitish haze where I didn't use solfast, right side you don't the haze. This also helps decal stick down tight so u don't blow decal off when clearing coating over decal.
File comment: Finished, 3 coats of lacqer satin clear with a light in between mist of antique gold lacquer to give some patina and to match the other dial scales.
File comment: Yes I know America is messed up. If this was customer's I would have to fix it.
 Post subject: Re: ZENITH SHUTTER DIAL SCALE RESTORATION
PostPosted: Dec Thu 19, 2019 9:57 am
Thanks Fred for showing that. Never had to do it and hope I wont. My one and only Zenith has a good black dial. It does have a veneer problem on one shoulder. Now if only you were nearer :D
Gary
PostPosted: Dec Thu 19, 2019 4:38 pm
A small imperfection in the decal lends to the credibility of the patina.
PostPosted: Dec Thu 19, 2019 7:47 pm
Thanks for posting this Fred. Great information.
I will not be filed, stamped, indexed, briefed, debriefed or numbered. My life is my own. I resign.
PostPosted: Dec Thu 19, 2019 8:49 pm
Beautiful work! Looks better than new most likely :D
My collection: https://www.radiomuseum.org/collection/ ... ickel.html
PostPosted: Dec Thu 19, 2019 8:58 pm
Nice work as usual.
PostPosted: Dec Thu 19, 2019 9:18 pm
How about starting with this one?
Got the new decals from Rock Sea Enterprises years ago.
PostPosted: Dec Fri 20, 2019 10:56 pm
WOW. I always enjoy reading through your projects. " A mist of antique gold for aging."
What a novel idea.
Freeman
PostPosted: Dec Sat 21, 2019 2:46 am
Great tip.
PostPosted: Jan Fri 03, 2020 5:03 am
Beautiful job Fred. Learned a lot. THANKS!! Mike McKenzie
