It is currently Mar Tue 31, 2020 8:16 am
 Post subject: Tung Oil
PostPosted: Jan Thu 16, 2020 2:38 pm
Is this good for coating a clean radio cabinet?
 Post subject: Re: Tung Oil
PostPosted: Jan Fri 17, 2020 1:16 am
I’ve used tung oil as a finish on many wood projects. Cutting boards, bowls, stuff like that. I have NOT used it on any radios. Tung oil is food safe and sustainable. If you like the tung oil look and feel. There is a variation that a hugely respected master woodworker, Sam Maloof, came up with that I have used on a lot of my woodworking projects. 1/3 Urethane (semi gloss) 1/3 Raw Tung oil 1/3 Boiled Linseed Oil. This is a wipe on finish and after 4 or 5 coats, wet sanding w/800-100 in between coats, it produces a velvety finish that everyone loves to feel. If you use it, I think you'll like it. but it's not "traditional." I prefer to use the original finishes when I'm restoring or refinishing antique furniture. Here's a photo of a chair I just finished using this tung oil recipe.
PostPosted: Jan Sun 19, 2020 10:35 am
Way to ruin a radio me thinks.
Gary
PostPosted: Jan Sun 19, 2020 12:49 pm
Clean, as in a clean original finish? Or clean, as in the old finished stripped to bare wood?
I believe tung oil is typically used on bare wood, not on over old finish.
Paul
...... how hard can it be?
PostPosted: Jan Sun 19, 2020 2:07 pm
I believe tung old is typically used on bare wood, not on over old finish.
Original finish
PostPosted: Jan Mon 20, 2020 2:23 pm
Site Admin
Most of what is sold as "tung oil" is just thinned varnish. Pure tung oil won't completely dry.
PostPosted: Jan Thu 23, 2020 5:24 pm
Original finish
Interesting...I had a friend tell me I was crazy for cleaning a dirty finished cabinet with gojo and that I should have used tung oil... I went to the store looked at the can and saw "apply to bare wood" and thought he must have been pulling my leg.
Maybe I'll test this on something I don't care about...
PostPosted: Jan Fri 24, 2020 9:14 pm
Electronic Memory wrote:
.......Interesting...I had a friend tell me I was crazy for cleaning a dirty finished cabinet with gojo and that I should have used tung oil... ...
I've used tung oil many years ago and while it gave an acceptable finish I would never apply it, or any varnish, finishing oil. etc. to a dirty finish. As others have said all the tung oils I have seen are actually more of a thinned varnish that would dry with dirt under the finish.
John KK4ZLF
Post New Topic Post Reply  [ 8 posts ]  Moderator: Peter
