It is currently Feb Tue 25, 2020 9:44 am
 Post subject: Best way to clean a cabinet
PostPosted: Jan Tue 21, 2020 8:04 pm
Hi
I have this nice zenith that has some little scratches and a slight water stain on top. What is the best way to just clean it up without spraying Lacquer on it etc...
Kevin....
 Post subject: Re: Best way to clean a cabinet
PostPosted: Jan Tue 21, 2020 8:10 pm
Clean with non-pumis GOJO hand cleaner and follow with Howard’s Resto-o-Finish... personally though that is a very nice high end Zenith and deserves a cabinet refinish at some point...
PostPosted: Jan Tue 21, 2020 8:31 pm
It's to good of a radio and I don't want to screw up the radio trying to out a better finish on it. Maybe down the road I will have someone do it for me.
Kevin....
PostPosted: Jan Tue 21, 2020 8:33 pm
Which Color do you think?
Kevin....
PostPosted: Jan Wed 22, 2020 2:55 am
Neutral, since that is what is there now!
Dale
PostPosted: Jan Wed 22, 2020 5:57 pm
I heard GO-JO is good, but use a furniture cleaner (not dual purpose clean & wax). I use Howards Restore-A-Finish and follow up with Howards Feed-N-Wax. Some state the Howards Restore slightly melts the finish fixing hairline cracks too.
PostPosted: Jan Thu 23, 2020 4:36 pm
I too have a Zenith radio that I am currently restoring. After reading the post, as Ktewell mentioned about scratches, what is recommended to remove these without severely scratching the original wood before before any kind of finish would be applied?
Thank you
PostPosted: Jan Thu 23, 2020 7:59 pm
Try using the 3 in 1 "miracle" mixture. 1/3 turpentine, 1/3 linseed oil, 1/3 vinegar. Amazing!
PostPosted: Jan Thu 23, 2020 8:37 pm
Thank you
Howard Restore-A-Finish is excellent with removing scratches. Only issue is the color array of stains Howard provides match your radio?
PostPosted: Jan Thu 23, 2020 9:13 pm
Art....You just wipe that on with a rag????
Kevin....
PostPosted: Jan Thu 23, 2020 11:45 pm
Yes. I can supply a "before" and "after" picture to show how it worked for me on a Zenith Super VII cabinet if you'd like to see it.
You MIGHT not need to apply new finish.
PostPosted: Jan Fri 24, 2020 12:04 am
I would love to see it
Kevin....
PostPosted: Jan Fri 24, 2020 3:16 am
Here is a radio I restored using Howards products. Like your radio it had scratches. It is simply waxed, no lacquer.
PostPosted: Jan Fri 24, 2020 3:20 am
Nice
Kevin....
PostPosted: Jan Fri 24, 2020 3:20 pm
Very nice! What about deep scratches? Any sanding required? Would this hurt the existing original wood grain? I have a few deep scratches that don't require any filler, but would need some sort of delicate sanding.
Any suggestions?
PostPosted: Jan Fri 24, 2020 5:29 pm
Any suggestions?
The Howard restore should cover up deep scratches as it is like a stain, but may not provide a shine on those deep scratches. The Howard Feed & Wax would shine up the deep scratches. Not perfect, but better than what you have now.
PostPosted: Jan Fri 24, 2020 7:13 pm
jimbenedict wrote:
Any suggestions?
After a certain point of deep you can hide but not get rid of scratches by Howards...when it hits that point either live with it or (sand and) refinish it.
PostPosted: Jan Fri 24, 2020 8:10 pm
I've tried the homemade version many years ago and also the pre-made version called Kramer's Best Antique Improver. Supposedly real turpentine is now hard to find and Kramer imports his from somewhere. Personally I wasn't too impressed with it but some folks love it so I guess it's a YMMV kind of thing.
I've refined my steps to what many others have suggested:
1. Clean with "white" Goop or Go-Jo hand cleaner (do not buy in orange container!)
2. Apply Howard's Restore-A-Finish or Old English if needed.
3. Apply Howard's Feed-N-Wax. Sometimes I'll substitute a car wax, Johnson's or Min-Wax paste wax, or walnut colored Bri-Wax, but I do really like Feed-N-Wax.
John KK4ZLF
PostPosted: Jan Sun 26, 2020 3:11 am
Here you go.
PostPosted: Jan Sun 26, 2020 5:10 am
Evidently, you are in Cincinnati OH.
Contact CARS (Cincinnati Antique Radio Society). http://www.cincinnati-antique-radio.org/Home_Page.php.
You will find others with your interest in radio and experience to share with you.
This antique radio club has meetings and a annual radio swap meet in June (Radiorama).
Dave Poland
Post New Topic Post Reply  [ 21 posts ]  Moderator: Peter Go to page 1, 2  Next
Users browsing this forum: Radio Fixer and 2 guests
