It is currently Jun Wed 23, 2021 6:23 am
 Post subject: Lab-Volt Fet multimeters
PostPosted: May Mon 17, 2021 1:25 am
hello again, i have an old Lab-volt Fet multimeter, i hope somebody can help me with the manual or schematic or the calibration procedure? mine is the green one, but i discover another model that looks apparently the same without the current section.
any help or ideas will be really appreciated
best regards
Pio
 Post subject: Re: Lab-Volt Fet multimeters
PostPosted: May Mon 17, 2021 7:24 am
Lab Volt equipment was sold to schools as training equipment, the schematics were never supplied. If you had a problem they were sent back to the factory for repair.
DM
PostPosted: May Mon 17, 2021 7:51 pm
Sometimes the calibration pots are marked on the PC board (e.g., zero adj, .5 VDC adj., etc.). Providing this information would make it possible for members to suggest a calibration procedure that would work. If this is not the case, it's possible to trace the circuitry and draw a schematic (or partial schematic) of the circuitry which would make it possible for members to suggest a calibration procedure that would work. If drawing a schematic is difficult to accomplish, for each calibration pot, it's possible to shunt the wiper and a terminal that is not connected to the wiper of the pot with a resistor that is 10 times the value of the pot and determine which functions and ranges are affected by the shunt. This information would enable members to suggest a calibration procedure. Minimally, I would expect there to be a zero adj., .5 VDC adj. and an AC adj. pot. Some meters may have more pots (e.g., both a .5 VDC and 1.5 VDC adj. pots).
PostPosted: May Mon 17, 2021 9:07 pm
I identify unmarked cal pots by feeding in a known voltage and then tweaking pots in turn until I find the one that has an effect on the meter reading. Ones that don't are returned to their initial positions until they are also identified.
RRM
PostPosted: May Tue 18, 2021 1:31 am
nice looking meters.. can't be referenced against know manufacturer products like many other ed items? i.e. my Eci scope was made by iwatsu and match model. never heard of lab-volt
only the dead fish go with the flow
PostPosted: May Tue 18, 2021 4:46 am
Mr. Google says this is the outfit that makes Lab-Volt equipment. He knows about almost everything.
https://labvolt.festo.com/solutions/2_e ... nstruments
A letter to them might get some data. I've had better luck with actual letters instead of email when looking for old product information.
RRM
PostPosted: May Sun 23, 2021 6:17 am
thank you for the input, the wiring scheme in those is difficult to trace because is tied with knots and the circuit is covered with varnish.
here are some pictures
best regards
Pio
File comment: that is the most i can take apart the pcb due the wiring tied and knots.
File comment: the ammmeters section is separated and no need ac power.
Users browsing this forum: Jthorusen and 30 guests
