It is currently Dec Wed 08, 2021 11:20 am
Post New Topic Post Reply  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: New Variac vs. Old Used Variac
PostPosted: Sep Tue 28, 2021 10:53 pm
If you do decide to buy a used Variac, brushes are available here :
http://www.carbonbrush.com/variacbrush.htm
I had them rebuild the brush on my General Radio 10 Amp unit.
Fast service and reasonable.
Respectfully Submitted,
Be_Zero_Be
You never used to be older.
PostPosted: Sep Wed 29, 2021 12:19 am
Fortunately, as the voltage drops, so does the current. :D
PostPosted: Sep Wed 29, 2021 1:16 am
Thanks to all the contributors. This is a really great thread!
The links to the replacement brushes are a godsend, as are COM-NAV-ECM's comments about service and fiddling about.
Note that beyond the obvious benchtop utility of a V/T, the information in this thread is important to people using and repairing Tektronix 575 and 576 curve tracers. Both of those devices prominently feature variable transformers in their collector sweep supply circuits. FWIW, the 575 and 576 V/T are not a custom Tektronix parts either. (At least not in mine) The ones I've seen are standard off the shelf items from the regular variable transformer manufacturers.
Thanks again to all the contributors!
Keith
coolblueglow
