It is currently Oct Thu 29, 2020 12:45 pm
 Post subject: EICO 320 Sig Gen
PostPosted: Jul Sun 06, 2014 11:18 pm
Recently picked up an EICO 320 Signal Generator on ebay. Found coil L1 is open. No RF Output from range "A". Everything else works fine.
Does anyone know where I might find a good coil either new or used? Or does anyone know the value of this coil in Micro Henries.
 Post subject: Re: EICO 320 Sig Gen
PostPosted: Jul Mon 07, 2014 1:35 am
HI:
HERE IS THE MANUAL,SCHEMATIC AND PARTS LIST.
http://www.softsector.hostingsiteforfre ... 20-322.pdf
FIRST MAKE SURE THE SWITCH CONTACTS ARE CLEAN.
IF THE COIL IS OPEN REMOVE IT AND CHECK THE SOLDER CONNECTIONS AND LOOK FOR THE OPEN WIRE.THESE ARE USUALLY REPAIRABLE.
WALTER-W2WIQ
Users browsing this forum: No registered users and 30 guests
