It is currently Feb Fri 21, 2020 12:56 am
 Post subject: Quig tools
PostPosted: Jul Mon 18, 2016 12:37 pm
link to hi-res image
I recently made up a batch of quig tools based on Al Klase's design.
I used the same basic materials: K & S 0.040" music wire and 1/16" and 3/32" brass tubing for the jig, and plastic tubing for the handle. Like Al, I soldered together parallel lengths of the 1/16" and 3/32" tubing. That was easy-peasy.
But Al then soldered a length of the music wire to the saddle between the two tubes. I couldn't manage to solder the music wire without unsoldering the tubing. Perhaps I could have made a fixture to hold things together for soldering, but I instead wrapped the bundle of the tubing and the music wire with a length of 26 gauge bus wire. This held everything together while I soldered it.
Al used thick-walled 5/16" diameter plastic tubing for the handle. Based on Al's photo, I think he used Plastuct butyrate tubing, which has an inside diameter of 3/16". I used Evergreen 1/4" styrene tubing for my handle instead. I used slow-cure epoxy to glue the tool into the handle.
The next day I touched up the ends of the tubing with a mill file and de-burred the center of the tubing with some small wire drills.
 Post subject: Re: Quig tools
PostPosted: Jul Mon 18, 2016 12:49 pm
Nice work! Looks good!
PostPosted: Jul Mon 18, 2016 1:21 pm
OK, I'll bite. Does Quig stand for Quick Insertion Gadget?
I made one of these from a pin vise I had several months ago and it makes using this method fairly painless.
Thanks for sharing this design, Steve.
73, de Chuck K4CCW
PostPosted: Jul Mon 18, 2016 2:13 pm
here's mine made from an Exacto knife handle
Users browsing this forum: joelandjoyce, Lou deGonzague and 15 guests
