It is currently May Fri 29, 2020 4:34 am
Post New Topic Post Reply  [ 46 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Need Help on Diagnosing a Sprague Tel-Ohmike TO-6A
PostPosted: Jul Mon 02, 2018 10:46 pm
Whether the meter drops when you drop voltage read depends on how leaky the cap is. Here is a bad way to test a cap, but a good way to see how the tester reacts. https://youtu.be/6E_qKxD2wDw. This is a better procedure but the test isn’t quite as stark. https://youtu.be/WlwSexqRRWg
PostPosted: Jul Tue 03, 2018 6:25 am
I have a dead meter from a TO-6, with a good face. It's here somewhere, I just have to find it, if you're interested. I replaced the whole meter with a Simpson TV-3.
Unemployed Analog Meter Technician. Simpson 260 specialist.
John, KK6WHY
PostPosted: Apr Sun 05, 2020 9:22 pm
Older Thread .... but I just came into a 6A and wondered if anyone happens to have the calibration procedure. BAMA has everything but, as apparently calibration was not part of the normal ops manual like it usually was...., and some web searching hasn't turned up much in the way of calibration instructions.
I can fake it by using what I've got and my experience from the 4 and 6 ... but always like having the correct stuff.... and no, I have not yet tried to figure out what the difference is between the 6 and the 6A. If I have to, I will ;-)
Thanks!
PostPosted: Apr Mon 06, 2020 1:54 am
HallmanLabs.com wrote:
Very little help was offered after I started asking technical questions about the unit vs. structural. Such as requesting simple reference voltages from anyone who owns a working TO-6/TO-6A.
I am working on restoring a TO-5A. A couple of guys here put together a TO-5 theory and functional guide, pretty detailed - 30 pages. Not really much difference in theory between a TO-5 and a TO-6. Someone else assembled a TO-5/TO-6 calibration guide.
These may help.
TO-5 final version.pdf [7.47 MiB]
Downloaded 15 times
TO-5 and 6 cal procedure.PDF [11.45 KiB]
Downloaded 25 times
PostPosted: Apr Mon 06, 2020 11:57 am
Thanks KX5....I've got the Mike Higgins writeup up on my site, and will add this as well. I appreciate your finding it. I may also do a detailed comparison between the TO-6 and TO-6A, since I"ve got both of them here right now. Stay tuned. I think I may also have a TO-4 around somewhere...will check and if so add it as well, although I believe it is much different from the 6
PostPosted: Apr Mon 06, 2020 7:22 pm
One thing that I found when reworking my TO-6 is that the unit may not be exactly the same as the schematic; I had one resistor that was absent, and another one was a different value. Evidently, they were tweaked during initial calibration.
Users browsing this forum: Google [Bot], Koby and 7 guests
