Page 1 of 1
[ 6 posts ] |
Author |
Atwater10
Post subject: Daven MU-20 Data Posted: Oct Sat 13, 2001 2:00 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 702 Location: Oakhurst, California 93644
Hello All, I wonder if anyone has tube data<BR>to test a Daven MU-20 amplifier tube? It has<BR>a 6 volt fillament and is a 4-pin triode.<P>Thanks, Chuck<P>------------------<BR>
Top |
Norm Leal
Post subject: Daven MU-20 Data Posted: Oct Sat 13, 2001 5:45 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 30811 Location: Livermore, CA
Hi Chuck<P> The number MU 20 means it has a gain of 20. At 6 volts the filament current is .25 amps. Plate voltage can be up to 150. Negative grid voltage -4.5 to -10.5 volts depending on plate voltage. Output resistance 40,000 ohms. This is how it's listed in S. Gernsback's Radio Encyclopedia 1927.<P> No currents are given. If it passes as a 40 should be ok.<P>------------------<BR>Norm
Top |
Atwater10
Post subject: Daven MU-20 Data Posted: Oct Sat 13, 2001 7:04 am |
Member |
Thanks Norm. Its a beautiful addition to my<BR>tube collection.<P>Regards, Chuck<P>------------------<BR>
Top |
busterdog57
Post subject: Re: Daven MU-20 Data Posted: Dec Fri 07, 2018 10:53 pm |
Joined: Jul Sun 12, 2015 9:47 pm Posts: 178 Location: 94502
Does anyone know what tubes are good substitutes for the Daven MU-20? Hoping 01a might do the trick...
Top |
Braithwaite
Post subject: Re: Daven MU-20 Data Posted: Dec Sat 08, 2018 1:11 am |
Joined: Nov Sun 04, 2007 6:01 am Posts: 3747 Location: Redding, CA
The best replacement will be a type 40 (240, 340) tube with an amplification factor of 30. The amplification factor of the Mu-20 was, of course, 20. The circuit will likely limit actual amplification of the stage to something less than 20. If amplification is not a big concern, an 01A with an amplification factor of 8 should work.
This thread should be moved to "tubes & parts", a category that did not exist at the time of the first post.
Norman
_________________ "No home is complete without music" - Capehart Sound Amplifying and Distributing Systems
Top |
busterdog57
Post subject: Re: Daven MU-20 Data Posted: Dec Sat 08, 2018 2:03 am |
Top |
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: bob91343 and 17 guests |
