It is currently Jul Wed 08, 2020 4:01 pm
 Post subject: tektronix 107
PostPosted: Nov Mon 11, 2019 5:02 am
I am repairing a signal generator and I am trying to find capacitors for it. Part numbers are 290041 and 290052. One is a dual 40mfd 250 volt and the other 125 mfd 350 vole.
 Post subject: Re: tektronix 107
PostPosted: Nov Mon 11, 2019 5:14 am
Did you check the usual suppliers? Those are not rare parts, I believe.
Bob
PostPosted: Nov Mon 11, 2019 5:15 am
The "updated" part numbers are 290-0041-00 and 290-0052-00.
Unfortunately, these can caps were discontinued by Tek in the 80s, so finding exact replacements would be for nil - the replacements would be at least 35 years old, and no longer reliable. It's best to replace them with individual capacitors of equal value.
The Tek Reistor/Capacitor common design guide lists capacitors of similar values on page 13-13:
http://w140.com/tekwiki/images/b/b8/Tek ... 89_ocr.pdf
You might find one that is currently available that will work.
Brian
PostPosted: Nov Mon 11, 2019 8:25 am
Digi-Key or Mouser will have the capacitors you need.
DM
PostPosted: Nov Wed 13, 2019 12:43 pm
They are both not critical.
For a simply repair you can use 2pcs of 47µF and a Set of 100µF parallel a 22µF.
For a fine restoration you can make empty the old C and insert the (smaller!) new in the case from the old.
If yo need selected C for time bases ask me I do that for friends, < 0.1% is possible.
Martin
Users browsing this forum: Eddy, KX5JSC and 8 guests
