It is currently Jul Wed 08, 2020 3:09 pm
 Post subject: Cushman CE-6A Frequency Range
PostPosted: Nov Sun 17, 2019 3:12 am
I thought this bit of info would be easy to find on the web, but it appears not to be.
Just need to know the range; I have the offer of one for free but from what I'm seeing it has limited HF ability.
73 Mark K3MSB
www.k3msb.com
 Post subject: Re: Cushman CE-6A Frequency Range
PostPosted: Nov Sun 17, 2019 8:25 pm
A CE-6A for free would be great to rescue.
The frequency range is a bit difficult to explain. These are more or less VHF-UHF two-way shop instruments, and the usual use would be 20 MHz-1000 MHz. BUT... the manual states that it generates 10 kHz to 1000 MHz. Some features require things like the broadband mixer plug-in and those start at 20 Mhz.
There was an HF plug-in divider thing that brought all features down into the HF range but that may have been for the CE-4 or CE-3. I am not sure you need it on a 6.
The generate aspect of these instruments isn't exactly a pure signal on only one spot frequency, to put it kindly. But they have their uses and are well worth getting.
The 6A has a high output feature, which at the time was usually used when tuning duplexers.
WB6NVH
http://www.wb6nvh.com
PostPosted: Nov Tue 19, 2019 5:32 pm
Greetings to Mark and the Forum:
The CE-6A generator according to the manual covers from .01 MHz to 999.999 MHz. The monitor portion is the same, depending on what mixer plug-in is in the unit. My mixer is a 317, which covers from 50 KHz to 1000 MHz.
I don't have manuals on any other front end plug-ins; they may be more restrictive.
Be sure to acquire the manuals that go with the unit if they are available. Cushman did engineering changes at the drop of a hat; it is almost true that no two units are absolutely identical. If you can obtain the manuals issued with the unit, you will have a considerable leg up on maintenance.
I had to reverse engineer the 100 Hz phase lock loop on mine due to the rather cryptic theory of operation discussion and almost complete lack of alignment instructions. The complete write-ups are on my web page at http://www.centcoast.com.
Regards.
Jim T.
KB6GM
PostPosted: Nov Fri 22, 2019 7:03 pm
Free and Working.... grab it. CE-6 is a decent unit... a bit dated, but better than the CE-5 I use for a doorstop. Also have a CSM-50A gathering dust like most of the other test gear these days.
Pete
PostPosted: Nov Fri 22, 2019 8:09 pm
So what good is my FM-10C? It's too big for the bench.
PostPosted: Nov Sat 23, 2019 6:40 am
Greetings to bob1943 and the Forum:
Where are you located? I'm sure our local ham club would love to have it! :D
Jim T.
KB6GM
PostPosted: Nov Sat 23, 2019 7:00 am
I live in the San Fernando Valley. My unit has some issues but seems basically to work. Since we get chastised for trading stuff outside of specific forums, reply in PM to avoid such.
Check me at qrz.com
Bob K6DDX
Users browsing this forum: No registered users and 20 guests
