It is currently Sep Mon 27, 2021 5:52 pm
Post New Topic Post Reply  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: Heathkit VTVM Resistors source
PostPosted: Nov Wed 20, 2019 12:36 am
bob91343 wrote:
Years ago HP solved the meter linearity issue by automating the scale printing for individual meters. I don't know the dates they did that or for which models.
It's described in the March, 1961 issue of the HP Journal:
https://www.hpl.hp.com/hpjournal/pdfs/I ... 961-03.pdf
It was first applied to the HP 400H, 411A, 412A, and 425A.
PostPosted: Nov Wed 20, 2019 12:39 am
bart wrote:
Interesting to see Stevebyan, I will start restoring and create a similar document with the results. Really good job there!!
Thanks. I also recorded the pre-replacement values of the resistors, just to get some data on how many drift out of tolerance.
I described the restoration of my IM-28 in this thread:
https://antiqueradios.com/forums/viewtopic.php?t=365180
PostPosted: Nov Wed 20, 2019 12:50 am
Barry H Bennett wrote:
So, how many million $ and million days did it take?
I only replaced two precision resistors, though the AC accuracy suffered a bit because I should have replaced two more resistors in the AC divider. So cost was about 40 cents. It took an evening to make the initial resistor measurements, a couple of evenings to actually restore the VTVM, and an evening to calibrate it.
And how can one do better than the linearity of the meter movement and dial scale itself ? ;-)
I got lucky, the meter linearity and scale are better than spec.
I don't expect it to remain that accurate over time and temperature, but I'm confident that it meets Heathkit's 3% spec on the DC ranges (except the low end of the 1.5 volt range).
Users browsing this forum: Ed in SoDak, Geoff Fors, stevebyan and 19 guests
