It is currently May Sat 30, 2020 12:41 am
Post New Topic Post Reply  [ 37 posts ]  Go to page 1, 2  Next
 Post subject: Short light on B&K 747b don’t work.
PostPosted: Jan Mon 06, 2020 10:25 pm
Ok guys I am trying to take the easy way out. I just finished calibrating my B&K 747b tube tester. I changed all capacitors 1st. All went well except for the setting of the short light. I was able to calibrate the grid emissions which is after the short calibration. I can turn R20 all the way both ways and can not get the short light to light. Any thoughts?
Last edited by oldtvsandtoys on Jan Mon 06, 2020 10:55 pm, edited 1 time in total.
 Post subject: Re: Short light on B&K 747b bong work.
PostPosted: Jan Mon 06, 2020 10:37 pm
is the lamp/light good? NE-1 neon lamp
PostPosted: Jan Mon 06, 2020 10:47 pm
for those who want the manual.
http://bama.edebris.com/download/b&k/747(2)/747.pdf
PostPosted: Jan Mon 06, 2020 10:56 pm
Do you have 100 volts on one side of the neon? Is the shorts switch making contact? Is your 1 meg resistor good?
DM
PostPosted: Jan Mon 06, 2020 10:57 pm
That’s would be a good question, but I have been told it’s rare they go bad.
PostPosted: Jan Mon 06, 2020 11:00 pm
DM
Good place to start. I will check in the morning. Thanks
 Post subject: Re: Short light on B&K 747b don’t work.
PostPosted: Jan Mon 06, 2020 11:09 pm
cool, check the lamp, check the circuit. We'll be here :)
PostPosted: Jan Tue 07, 2020 4:52 pm
Ok found the problem I need a new NE-1 neon lamp. One wire broke off. Part number 401-002-9-003
Anyone have a new one or used on to sell?
PostPosted: Jan Tue 07, 2020 7:28 pm
I found this: https://www.interlightus.com/light-bulb/NE-1
Still, that's a rare bulb. I might convert that to use a different bulb if it were mine. I found some pictures in another thread here. Is that a bayonet base? Yoy might be able to find an incandescent that will fit.
PostPosted: Jan Wed 08, 2020 1:00 am
An incandescent lamp will not work. The circuit depends on the firing voltage of a neon lamp.
There is a possibility that NE-1 is a typo or just refers to the ID in the parts list (like R1, C1).
I think the actual neon lamp numbers start with NE-2 and there are variations of NE -2.
Can you see any marking on the bulb? Sometimes there are letters imprinted in the glass at the pinch were the wires exit.
Glow lamp data.
https://static1.squarespace.com/static/ ... ations.pdf
PostPosted: Jan Wed 08, 2020 1:14 am
How did you determine the neon lamp is defective, you cannot check it with an ohmeter.
DM
PostPosted: Jan Wed 08, 2020 1:17 am
It is the "NE-1 lamp", a thread covering the replacement exists. Does look like a NE-2 with resistor, Sal sells cheap, ad to right
viewtopic.php?f=8&t=205856
PostPosted: Jan Wed 08, 2020 1:48 am
To end all this confusion PM me with your address and I will drop a couple of these bulbs in the mail for you.
DM
PostPosted: Jan Wed 08, 2020 1:54 am
wow, solved, way to go DM !! woo hoo
PostPosted: Jan Wed 08, 2020 5:11 pm
devilsmist may have "solved" the problem but I think some of you are still in the dark.
There are two versions of that B&K tube tester, 747 and 747B. That combined thread glue_ru linked to
confuses the two. The main differences between the two is the pilot light system. The shorts circuit is the same however. The original 747 used a neon lamp and a resistor across the primary of the power transformer, which is the usual set up for a pilot light, it has two neon lamps in total. The 747B has the pilot light as part of the tube filament supply, it serves two purposes, one a power indicator, the other is filament current draw. That pilot lamp is a low voltage incandescent and is driven by a transistor circuit that indicates that the tube filament is drawing current.
The original 747 has a fuse inside on the filament circuit. The 747B has a circuit breaker on the panel for the filament circuit.
Neon lamps, incandescents and LEDs have very different electrical characteristics.
https://www.giangrandi.org/electronics/neon/neon.shtml
PostPosted: Jan Wed 08, 2020 10:54 pm
ugh
PostPosted: Jan Wed 08, 2020 11:06 pm
DM
When checking r20 I looked at the bulb and could see a broken wire on the bulb. The wire broke at the glass so I can’t fix it.
PostPosted: Jan Wed 08, 2020 11:12 pm
glue_ru wrote:
I don't believe it is solved that easily or by someone barging into every thread acting like THE expert, not buying DM's BS
DM didn’t solve the problem, I found the broken wire when I was checking other parts of the circuit. All DM did was offer me a new bulb and I thank him for that.
Let’s all just get along and not turn this into Videokarma.
PostPosted: Jan Wed 08, 2020 11:24 pm
https://www.antiqueradios.com/forums/vi ... 8&t=205856
Ok who is Sal?
PostPosted: Jan Thu 09, 2020 12:24 am
I believe he means "Sal's Capacitor Corner" which advertises on the right border of the pages here.
He is selling NE-2 lamps with and without resistors. Less than a dollar.
I just wanted to point out that neon bulbs may not being as simple as they look.
It is possible that a standard NE-2 will work. You could try it and see if the adjustment range of the
calibration pot will let it work OK.
With an application like a pilot lamp across the 120 VAC line the breakdown (firing) is not very critical,
the voltage present is way over the breakdown just about any of the neon lamps.
With a tester circuit like in this tester (very similar to any tube tester shorts circuit) the voltage might be more special.
If you can't see any markings on the bulb, I could open up my 747 and see if I can tell what it might be.
Users browsing this forum: Barry H Bennett and 21 guests
