It is currently Oct Sun 24, 2021 7:57 am
 Post subject: General radio 1390 random noise generator
PostPosted: Jan Sun 12, 2020 5:15 am
Does anyone use one of these?
Curious usefulness of it?
 Post subject: Re: General radio 1390 random noise generator
PostPosted: Jan Sun 12, 2020 5:11 pm
I don't own one, but do own a couple of other Gaussian noise generators. They have many purposes, such as room acoustic measurements, microphone and loudspeaker measurements, filter measurements, and bandwidth comparisons. Nowadays Gaussian generators are generally used in conjunction with real time analyzers of 1/3 octave or better resolution.
PostPosted: Jan Sun 12, 2020 9:56 pm
I have and use one for audio work, but quite often I grab a much smaller battery operated solid state one I built when the National noise generator chip was available. I put a pink noise filter on that. You can add same for the GR unit as their schematic is available somewhere, if you can't find a factory one. Wow, I'm dating myself- that was quite a while ago.
PostPosted: Jan Mon 13, 2020 2:14 am
I appreciate both responces.
I did download the manual.
Curious what that part number of the national ic was.
PostPosted: Jan Mon 13, 2020 2:25 am
I found it
http://www.discovercircuits.com/N/noisegen.htm
PostPosted: Jan Mon 13, 2020 3:05 am
I have a little small solid state Heath white / pink noise audio generator that runs on a battery. It was paired with an audio analyzer that was unrepairable, as I recall. Frankly I do not recall ever using it for anything at all. But when I ever need it.........
PostPosted: Jan Mon 13, 2020 6:50 pm
Wandering OT, you can do a rather nice noise generator by breaking down the B-E junction of common transistors and amplifying the result. With careful selection they can be good far into the RF region. A common application is an antenna noise bridge. I also have the GR higher frequency noise generator, 1383, that goes to 20 MHz.
PostPosted: Sep Fri 03, 2021 6:51 pm
The manual for the General Radio 1390-B Random Noise Generator is readily available. I've just acquired the earlier version, the 1390-A. The -A is missing the -B's output attenuator, and has other minor differences. Does anyone know where I can find a scan of the manual for the 1390-A?
PostPosted: Sep Fri 03, 2021 8:56 pm
Those white noise ICs are just long shift registers with feedback. You can do it with logic ICs. Don Lancaster wrote a number of times about pseudo random sequencers like this.
PostPosted: Sep Sat 04, 2021 3:46 am
I've also owned a couple of them over the years. There are numerous circuits out there for rolling your own using a very few ICs.
PostPosted: Sep Sun 05, 2021 11:39 am
I use the GR devices as a source of random numbers for a variety of experiments. I've built and tested several versions similar to this:
I've also built and tested simple devices based on atmospheric noise....just turn on the radio and capture the audio, followed by some signal processing. Here is a link to an interesting site based on QRN:
https://www.random.org/
Another interesting site, which uses radioactive decay:
https://www.fourmilab.ch/hotbits/
73 Dean
PostPosted: Sep Sun 05, 2021 3:13 pm
Mike,
Yes, you've owned one because you sent it to me for which I am still grateful! I found it very useful when used in conjunction with my old Tek 492 spectrum analyzer to look at filter response curves. I have since upgraded to a Micronetics NOD5200. The GR stops at 20Mhz and I wanted to go wider. Also, the NOD is "calibrated" so it is more useful when looking at noise floor and such. I still have the 1390 but I need to work on it to find an intermittent that makes the output jump up and down.
Tony
Oops, sorry. You sent me a 1383. Oh well, it's been a while since I looked at it. Still made good use of it!
Tony Casorso
PostPosted: Sep Mon 06, 2021 4:15 am
Hi Tony, Glad to see you got some use out of it.
Users browsing this forum: Google [Bot] and 14 guests
