It is currently May Sun 31, 2020 1:15 pm
Post New Topic Post Reply  [ 35 posts ]  Go to page 1, 2  Next
 Post subject: Frequency Counter-Cyometer advice needed
PostPosted: Apr Sat 04, 2020 7:19 pm
Vintage analog signal generators are difficult to tune precisely. Most of us use a frequency counter to dial them in. Is a cheap Chinese cryometer a reliable modern means to accomplish digital accuracy for our old generators? If so which one do you recommend? Thank you and be well.
"CIVILITY IS RECIPROCAL"
 Post subject: Re: Frequency Counter-Cyometer advice needed
PostPosted: Apr Sat 04, 2020 8:42 pm
A "cryometer" (not cyometer mentioned in the title)) is a thermometer for measuring very low temperatures. Probably won't work with an RF signal generator.
PostPosted: Apr Sat 04, 2020 8:58 pm
I have been impressed with the PLJ-8LED "cymometer" from Sanjian studio, China via Ebay.
A copy of the user manual is available: https://www.manualslib.com/download/152 ... led-C.html
-Chuck K7MCG
PostPosted: Apr Sat 04, 2020 9:08 pm
Note to self: Proofread post before sending. I know what a CRYOMETER is but somehow an R wandered into CYOMETER. Please note: My subject says CYOMETER so the "won't detect RF" wasn't revelatory. Thank you for the specific recommendation K7MCG. I'll order one and report back.
PS. Wasn't there a vintage TV SOB STORY contestant program that measured audience sympathy with a cryometer? :D
PostPosted: Apr Sat 04, 2020 10:50 pm
I ordered the PLJ-8LED Cyometer from eBay. PLJ-8LED-H RF Signal Frequency Counter Meter Tester Module 0.1~1000MHz LED KW. Less than $13 shipped if anyone is interested. The "CRYOMETER" typo was the spell correct in this program. It doesn't recognize cyometer.
PostPosted: Apr Sat 04, 2020 11:03 pm
I am sorry, but this one has me stumped. What is a Cyometer ? Looking on the web has a lot of stuff related to every thing but electronics (or at lest a lot of stuff that overloaded my search). Is this a frequency counter that can be offset by the IF frequency to get a direct readout of the radios tuned input frequency ?
PostPosted: Apr Sun 05, 2020 12:23 am
As Chuck said above, it’s “cymometer”. It’s a synonym for “frequency counter”. Why the Chinese use that term in their eBay ads, I don’t know.
PostPosted: Apr Sun 05, 2020 1:57 am
I've bought and used several of these and they are one of the
best test equipment bargains around IMO. Yes, the 6 or 8
digit version will work fine for your sig gen. Make sure you
look at the manual as it can be programmed for a number
of things like blank leading digit, gate times, brightness, etc.
My fave is the blue. No rational reason for it other than its
unusual and stands out next to other equipment that uses
red LED displays.
One thing to know...there are two connectors with wires included.
The one going to the power is correct (red +, black -)
but the input connector may be backward (red ground, black input).
Check board labeling to be sure.
Steve
PostPosted: Apr Sun 05, 2020 3:24 am
Thanks for clarifying , it probably one of those direct translation programs that don't always make sense after translation.
PostPosted: Apr Sun 05, 2020 3:30 am
Glad this came up. Was just getting ready to ask on here about frequency counters.
PostPosted: Apr Sun 05, 2020 3:32 am
Thank you Zarco for the heads up regarding the input polarity. Will definitely check the board. This unit comes without a case or box. How did you choose to house it?
PostPosted: Apr Sun 05, 2020 5:41 am
These are great little counters. I put one in my Gates modulation meter so I have both parameters in one spot. I too like the Blue display and put a piece of 3M blue transparent tape over the display to increase the contrast.
ClickthePic
PostPosted: Apr Sun 05, 2020 3:07 pm
Some of mine will be mounted in receivers. One of the nicest features of these is
you can program in an IF offset which makes them a nice upgrade for older
single conversion receivers.
The case I've used was the extruded aluminum from an old Hayes modem.
You can saw these in half to get two cases. Its the perfect size for the 6 digit.
Be creative. I've also made cases for things like this from walnut
blocks (fire wood) by hollowing out the center. Takes time but look
great.
Steve
PostPosted: Apr Sun 05, 2020 5:13 pm
Here is my version of one of these frequency counters on an Eico 324. see viewtopic.php?f=8&t=350360. You don't need eight digit display for any of these signal generators, I could barely fit this 5 digit counter.
PostPosted: Apr Sun 05, 2020 5:19 pm
Thanks for the photos. Mounting directly into the signal generator makes sense of course. I have been thinking of a creative case and will no doubt find something that works. I now regret tossing an old digital clock. It would have been perfect for this. If I can bring myself to cut an opening in my SG what do you guys recommend for a method that results in a clean opening?
PostPosted: Apr Sun 05, 2020 5:41 pm
I used one of these nibbling tool and then flle it clean.
PostPosted: Apr Sun 05, 2020 6:05 pm
https://adelnibbler.com
PostPosted: Apr Mon 06, 2020 7:45 am
:D
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Apr Mon 06, 2020 5:19 pm
CYOMETER or CYMOMETER. That is the question :o
PostPosted: Apr Thu 30, 2020 6:05 pm
The PLJ-8LED-H RF Signal Frequency Counter Meter Tester Module arrived today with no instructions. Does someone have a manual that can be posted. A link? Previous poster alerted me to the polarity at the input end but I don't know what the DC input voltage should be for the display. Also, those of you who wired it into your generator directly and mounted it on the front might post a wiring diagram? Thank you.
