It is currently Jan Fri 15, 2021 10:06 pm
 Post subject: Eico 315 controls
PostPosted: Apr Thu 09, 2020 4:32 am
Could someone explain the multiplier and attenuator controls on the Eico 315. I just checked resistors and recapped. Seems to be working properly. The multiplier increased the signal as I expected but how are these used when doing an alignment. Thanks
 Post subject: Re: Eico 315 controls
PostPosted: Apr Thu 09, 2020 9:00 am
The "multiplier" control is just the coarse adjustment of the output level. The one labelled "attenuator" is the fine adjustment. Use both as required to get the appropriate output level.
-Mark
PostPosted: Apr Thu 09, 2020 4:29 pm
You want to use the least amount of signal strength possible to make your alignments.
These controls allow you to do this. :D
Users browsing this forum: ACORNVALVE, bob91343 and 16 guests
