It is currently Oct Wed 27, 2021 4:45 am
 Post subject: Precision 612 tube tester problem
PostPosted: Sep Sat 04, 2021 3:58 pm
i have a precision model 612 tube tester the line voltage will not adjust too the center line it comes near but will not adjust too line with or with out vaccum tube in place i tried cleaning the rheostat but no change anyone have any ideas thanks Greg wa2oro
 Post subject: Re: Precision 612 tube tester problem
PostPosted: Sep Sat 04, 2021 6:04 pm
Must be a rectifier problem. Measure the filament voltage to see if it's also low, or normal.
PostPosted: Sep Sat 04, 2021 6:34 pm
hi Bob i checked out the tube 5y3 it was ok but i will check the voltage and maybe just try replacing the 5y3 thanks greg
PostPosted: Sep Sun 05, 2021 3:20 pm
It is rare that the rectifier tube goes bad, it has a light duty life. More likely that the line voltage control is bad, to test it unsolder one of the
3 outer wires then you can check it with an ohm meter. It should read close to 300 Ohms. Also possible that you have a bad meter.
These are the usual items that could cause your problem.
Bill
PostPosted: Sep Sun 05, 2021 3:34 pm
hi Prutser good idea will check for 300 ohms also there is a pot that controls the plate voltage for the 5y3 should be 300vdc if that is off it might effect the line voltage reading thanks greg
Users browsing this forum: 8bitmime and 15 guests
