Maybe someone reading has the actual Simpson procedure, and if so, please post or E-mail me if it's something not postable.
I've always set the meter series resistor first, then set the overall meter sensitivity with the meter shunt resistor next, but I've started wondering if the shunt should be set first instead. It's possible that the order makes no difference, since the meter series resistor is set in isolation. Does anyone know?
This schematic is a typical 260. In this example, R-27 is the meter series resistor (as it's similarly designated in lots of Simpson models), and R-32 is the shunt.
