It is currently Jun Tue 22, 2021 11:38 pm
 Post subject: Lube for wheel and turntable patter?
PostPosted: Dec Wed 05, 2018 5:58 pm
What do you use for a lube on the wheel and turntable platter?
 Post subject: Re: Lube for wheel and turntable patter?
PostPosted: Dec Wed 05, 2018 6:45 pm
Phonolube
William
PostPosted: Dec Wed 05, 2018 6:55 pm
One drop of turbine oil on the idler wheel center shaft, and a small amount of Lubriplate, red or green Rykon grease, or black moly auto grease on the center spindle and bearing.
PostPosted: Dec Wed 05, 2018 11:38 pm
And a drop of oil on motor shaft top and bottom.
PostPosted: Dec Thu 06, 2018 1:47 am
I have some turbine oil, I've used it on the motor and the wheel. I've used phonolube on all the greasable parts underneath. I don't have any black moly, lubriplate, or Rykon. Noone sems to have it locally either. I have ordered some moly from napa. The platter does make some noise when turning, so I thought it would need something. It'll get the moly when it comes in.
PostPosted: Dec Thu 06, 2018 3:02 am
You can get moly grease at auto parts stores. Just look for “Ford-Mercury-Lincoln” grease. It’s an NLGI #2 grease containing Molybdenum.
-David
PostPosted: Dec Thu 06, 2018 8:10 pm
The auto grade black moly is too thick for my tastes. I use a version that was marketed specifically to electronics shops back in the day. I don't recall the brand of the little tub — I keep a plastic syringe with a flex tip packed with it for ease of application. It's thin and I'm guessing NLGI 1, but I have no specs to prove it.
Once it's gone, I may start using Mobil Polyrex EM, simply because I have so much the stuff left. It's high quality lube. At NLGI 2, it's a bit thicker than my black moly, but I haven't been able to find a tub of my thinner version of the moly. :(
Since GC's phonolube is d/c and pretty much NLA these days, a lot of people have turned to Super Lube synthetic, which, like silicone, is safe for most plastics. Super Lube is available in various consistencies: https://www.super-lube.com/multi-purpos ... colon-ptfe
Post New Topic Post Reply  [ 7 posts ]  Moderator: Alan Voorhees
Users browsing this forum: 1988bluebird and 13 guests
