It is currently Sep Wed 30, 2020 11:55 pm
 Post subject: Microphonic sounding screech - '53 Cobramatic
PostPosted: Oct Thu 24, 2019 1:21 pm
I have a 1953 tabletop Zenith Cobramatic phonograph. It plays very well, but, for no obvious reason breaks into a very loud crackling screech that sounds like it with blow the speaker! It doesn't seem to happen because of volume or a loud point on the record. It's made the unit basically unusable. A friend said to tap the tubes when it's playing and see what happens. It has a new multi-use green/red needle and what I believe is the original cartridge. Thanks all for any information or ideas.
 Post subject: Re: Microphonic sounding screech - '53 Cobramatic
PostPosted: Oct Thu 24, 2019 2:02 pm
Easy...
First spray the tube sockets with Deoxit. Then try the 6J5 or 12J5, whatever it uses as the phono preamp tube.
The issue is somewhat common.
PostPosted: Oct Thu 24, 2019 2:48 pm
OldRestorer wrote:
Easy...
Many thanks Kirk!! Mine's the 12J5. The phono is too nice to not be enjoyed.
PostPosted: Oct Thu 24, 2019 9:45 pm
Awwww,
I sold mine last year to get the S-9011. I sold mine with the 45 adapter stupidly...
PostPosted: Oct Thu 24, 2019 11:02 pm
OldRestorer wrote:
Awwww,
I found the adapter on eBay and jumped at the opportunity. I got this one from Terry several years ago, and although it plays fine with a very good double cone replacement speaker, it has a low thumping sound that drowns out when the record is playing. I ordered a good tested replacement tube and am looking forward to hearing this unit play without screaming at me! LOL. It is a beautiful Cobramatic that you don't see or hear about much. I honestly thought it was from the late '40's. Kinda of deco for '53.
PostPosted: Oct Fri 25, 2019 2:24 pm
Thumping is the idler. It wont go away unless you get it redone. I have the same low bump but I dont mind it since I also cant hear it when the player is active.
PostPosted: Oct Sun 27, 2019 2:36 pm
Thanks Kirk. When the set is running for about 15 minutes the thump gets much quieter. I'll probably leave it as is. I got the new tube, but probably the worst choice (I was later learn) which is a glass Tung-Sol. It turned out to be 100% better though. It slightly goes into a short low microphonic buzz if you push the volume on certain recordings, but it doesn't go into the ripping screech like the original tube.
PostPosted: Oct Sun 27, 2019 4:42 pm
Ya know,
I could have easily sent you the tube. If the problem is solved then great. If you want me to send you another tube to try let me know.
Kirk
Post New Topic Post Reply  [ 8 posts ]  Moderator: Alan Voorhees
