It is currently Jul Sat 11, 2020 10:09 am
 Post subject: Vintage admiral
PostPosted: Nov Fri 08, 2019 3:58 am
I recently got this admiral vintage record player but I have no idea what year it from and what needle it need any thing on this will help thank you
ITEM# 85289
SAMS# 931-3
MODEL/CHASSIS: YK8349
TYPE : SAMS PHOTOPACT
 Post subject: Re: Vintage admiral
PostPosted: Nov Fri 08, 2019 7:46 am
Welcome to the phono forum.
1. If you have the photofact 931-3, you will see under the parts page 21,
listings for cartridges used in the Admiral changer.
Admiral cart # 409C86-1, stylus # 98C95-55
Alternate cartridge:
E-V (Electro-voice) cart: # 5257D, stylus # 3316-DS
2. Your photo is unrecognizeable, please re-size and post
a photo of the record changer and cartridge.
3. Contact Gary @ the voice of music.com for the stylus/needle.
4. Have you checked that the cartridge is functional ?
Rub your finger gently over the end of the cartridge where the
stylus saddle is. You should hear some noise through both sides of
the stereo speakers.
Hotwax
PostPosted: Nov Fri 08, 2019 5:27 pm
Thanks for the photo.
Will you take the records off the changer and take
a more clear photo of the record changer ?
From here, it actually looks like a BSR-made record changer
with a tetrad style phono cartridge.
Hotwax
PostPosted: Nov Fri 08, 2019 10:06 pm
The changer is a BSR and is probably a replacement. The original changer in that model would have been an Admiral/Ensign.
PostPosted: Nov Mon 11, 2019 7:59 am
Here are the other pic guys
PostPosted: Nov Mon 11, 2019 11:08 pm
1. Yes, that record changer is a BSR brand with a Tetrad
stereo cartridge.
2. Turn on the phono and rub your finger gently across
the rubber saddle where the stylus/needle should fit.
If you get sound from both channels, the cart is probably OK.
3. Here is a reference page for Tetrad styli 854 from the Voice of Music.
There are several other Tetrad styli types, too. Contact Gary at V of Music to
confirm which cartridge you have in the BSR.
http://thevoiceofmusic.com/catalog/part ... ategories=
