It is currently Jul Sun 12, 2020 1:38 pm
 Post subject: Sonotone 2ta mono cartridge
PostPosted: Nov Mon 11, 2019 2:43 am
How do I ground this cartridge when there are only two connections on it. I hear hum when the turntable is connected to my Midwest 162r radio. Any suggestions would helpful.
 Post subject: Re: Sonotone 2ta mono cartridge
PostPosted: Nov Mon 11, 2019 3:00 am
I didn't mention an important thing, the record player is not original to the Midwest. It is a Philco model from 1959.
PostPosted: Nov Mon 11, 2019 3:19 am
How about some photos of the record changer ?
Underside phono connections and tonearm/cart
connections. Top of changer with platter removed.
Best,
Hotwax
PostPosted: Nov Mon 11, 2019 3:45 am
Photos, lousy focus took them with my kindle.
PostPosted: Nov Mon 11, 2019 3:30 pm
Does the hun go away when you short the two cartridge leads?
PostPosted: Nov Mon 11, 2019 8:18 pm
How do i short the leads? I restore radios i know nothing about phono cartridge wiring.
PostPosted: Nov Mon 11, 2019 11:00 pm
1. With the amp powered up, just touch the 2 leads together.
2. From the photos, it appears that the audio leads are
surrounded by meshed wire ( shielded ).
And that there is a clip soldered onto the mesh wire.
Is this the case ?
3. Have you cleaned the Sonotone connection blades and
the inside of the clips on the cartridge wires ?
Hotwax
PostPosted: Nov Tue 12, 2019 1:39 am
What kind of wire are you using to connect the phono? To me it looks like zip cord. Or lamp cord. If so, then that's the problem. You need to use shielded cable. It has a center conductor with a wire mesh around the outside that shields it from hum. You can use an old RCA to RCA patchcord and just cut off one end. Just make sure it's shielded cable.
PostPosted: Nov Tue 12, 2019 3:38 am
You are right sir i am using a cable that i had lying around. Tomorrow i will put in a good shielded cable and try it out. I will report back to all with success or failure.
PostPosted: Nov Tue 12, 2019 5:07 am
Make sure the ground lead connects to the metal changer chassis as well as the cartridge lead.
-David
Post New Topic Post Reply  [ 10 posts ]  Moderator: Alan Voorhees
