It is currently Aug Sat 24, 2019 7:07 pm
 Post subject: AK 40 transformer cans
PostPosted: Feb Sun 22, 2004 6:32 am
I now have both small cans emptied of their tar and contents. An article I read says that the transformers can be replaced with A53C's from AES. One of the older transformers is smaller and more cylindrical in shape. Is it also replaced by the boxier A53C? confused... Also I have noted that these transformers have 4 wires coming from them and the A53C's have 5 wires...what to do? Thanks for any and all help!<BR>P.S. started learning to read schematics today...not as bad as I first imagined!<P>Timnic<P>------------------<BR>Married to a card holding member of WAPSBINO; Wives Against Power Supply Baking In New Ovens!
PostPosted: Feb Sun 22, 2004 5:13 pm
Just ignore the center tap on the A53C secondary. Stancor used to make A53s that didn't have the tap, but I guess it's easier for vendors to stock just one type.<P>------------------<BR>
PostPosted: Feb Sun 22, 2004 9:06 pm
Thanks for the info. Can I use the A53C in both cans, though?<P>Timnic<P>------------------<BR>Married to a card holding member of WAPSBINO; Wives Against Power Supply Baking In New Ovens!
PostPosted: Feb Sun 22, 2004 11:19 pm
Yes. The original transformers had slightly different peak frequencies, and were "staggered" to improve the overall response. Modern transformers aren't peaked like that, so they can be the same without accentuating any particular frequency.<P>------------------<BR>
PostPosted: Feb Mon 23, 2004 1:33 am
The large can was a 4.5:1 ratio & the small was ~3:1. I believe the A53 is a 3:1. If you use it in the large can, you will lose some volume, but it shouldn't be serious.<P>------------------<BR>
PostPosted: Feb Mon 23, 2004 1:36 am
So should I get something different so that I don't lose volume? Is there a 4.5:1 replacement available? Thanks,<P>Timnic<P>------------------<BR>Married to a card holding member of WAPSBINO; Wives Against Power Supply Baking In New Ovens!
PostPosted: Feb Mon 23, 2004 2:28 am
You'll never notice the difference.<P>------------------<BR>
PostPosted: Feb Mon 23, 2004 4:34 am
Alan is right, besides I've never found a source of 5:1 AFTs that would fit in the can.<P>------------------<BR>
Post New Topic Post Reply  [ 8 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: egg, valley and 8 guests
