It is currently Feb Sun 23, 2020 2:16 am
 Post subject: Am I using this wrong? Hikock 510x tester
PostPosted: Nov Thu 12, 2015 6:13 pm
Someone gave me an almost pristine Hikcock 510x. Anyway I have used a few newer Hikcocks before which had the 6 volt fuse bulb but this one seems to be behaving incorrectly or at least I think it is. When I insert a tube, and then do a line adjust I notice the fuse bulb goes to 100% full power. As in its fully lit and not the dull glow as seen on the others I've used. Otherwise it works fine. But I wasn't sure if these are supposed to burn the bulb right up to the bleeding edge like that.
 Post subject: Re: Am I using this wrong? Hikock 510x tester
PostPosted: Nov Thu 12, 2015 6:26 pm
No that is not normal. It is only going to light semi-brightly if you test a tube like a 5Z3.
"I just might turn into smoke, but I feel fine"
http://russoldradios.com/
PostPosted: Nov Thu 12, 2015 6:27 pm
Sounds like it may have the wrong bulb in there. Should be an 81, USA made.
PostPosted: Nov Thu 12, 2015 6:37 pm
The one that's in it I believe is a no.81. It says " 6-8 volts" on the side. So that seems to be correct.
PostPosted: Nov Thu 12, 2015 6:54 pm
I think that is the same or similar to the 51X (that I had for sale)?
Pictures:
viewtopic.php?f=15&t=278646
I you have an original one and would like to trade for a calibrated one - with a few extra sockets, I could be persuaded.
PostPosted: Nov Thu 12, 2015 7:41 pm
yes, that is the same as I have and I might just consider your offer actually. I don't care if something has been modified as this is more for me to use for testing big pins. I don't think anyone has done anything to this one. I cracked it open to install a new plug and its all original inside. I assume you live in Nor-Cal? If someone buys yours that is fine as I would like to think about this for a little bit.
PostPosted: Nov Fri 13, 2015 3:06 am
S. Oregon,
I was not going to bump the listing. The only reason I considered selling it was because of the extra sockets. I have a collection of testers as well as radios.
Let me know.
PostPosted: Nov Fri 13, 2015 5:05 pm
It was the bulb. I'm not a "light bub" expert and just assumed that the one in there was the right one, which it wasn't. I got the right one and all is well. So I reckon I'll just use this one anyway. Thanks guys!
Users browsing this forum: dninneman, Lou deGonzague and 13 guests
