It is currently Jan Sat 22, 2022 12:26 pm
 Post subject: philco 51 538
PostPosted: Sep Sat 25, 2004 9:31 pm
Greetings:<BR>I need some help with this tube line up. Nost-air does not list this model.<BR>I have a 14E6 where other similar models show a 14B6. Could I sub a 14B6 for the 14E6?<BR>Thanks,<BR><P>------------------<BR>
PostPosted: Sep Sat 25, 2004 10:00 pm
The pin outs are the same for both tubes one is<BR>14E6<BR>Twin Diode - Medium-Mu Triode <BR>14B6<BR>Twin Diode - High-Mu Triode<P>You prob won't get the same performance out of the 14e6 as you would the 14b6. might be a volume issue.<BR><P>------------------<BR>
PostPosted: Sep Sat 25, 2004 10:38 pm
Thank you simlex1040.<BR>Looks as if I will keep the 14E6 in the unit since it has tested OK.<BR>Thank you, again for your response.<P>------------------<BR>
Post New Topic Post Reply  [ 3 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: amyotte, bluebellyyankee, Majestic-12 [Bot], Tbone and 8 guests
