It is currently Jul Thu 02, 2020 7:26 pm
 Post subject: Cap Replacement Elac Miracord 10
PostPosted: Mar Tue 14, 2017 5:54 pm
Hi,
I am overhauling an Elac Turntable and feel I should replace the 55 year old capacitor.
Wondering if this is a "motor start", "motor run" or some other type.
Also wondering about the "+50 Ohm" marking on it.
It would be great if someone could recommend a replacement part.
Thanks in advance,
Joe Y
Collecting audio gear and radios because I couldn't afford to buy it when I should have.
 Post subject: Re: Cap Replacement Elac Miracord 10
PostPosted: Mar Tue 14, 2017 10:52 pm
Cornell Dubilier Electronics (CDE)→ 942C20S47K-F
0.047µF ±10% Film Capacitor 500V 2000V (2kV) Polypropylene (PP), Metallized Axial.
Type 942 round, axial film capacitors utilize a hybrid section design of polypropylene film, metal foils and metallized polypropylene dielectric to achieve both high peak current as well as superior rms current ratings. This series is ideal for high pulse operation and high peak current circuits.
https://www.vinylengine.com/turntable_f ... 18&t=83888
Elac miracord 10 & 10H service manual...
https://www.elektrotanya.com/cgi-bin/download2.cgi
PostPosted: Mar Wed 15, 2017 12:26 am
Greg,
Thanks for the great information! This is just what I needed,
The link to the user manual is broken, but I'll poke around and try to find myself a copy.
Thanks again,
Joe Y.
PostPosted: Mar Wed 15, 2017 1:18 am
Whoops... my bad.
this should work... :) https://www.elektrotanya.com/elac_mirac ... nload.html
Wait for the ...processing... notice to change to Get Manual ←it takes a while!
or... shoot me an email and I will send you a copy.
Greg
PostPosted: Mar Wed 15, 2017 3:01 am
As the schematic on the capacitor shows, it is a 0.05 uF capacitor in series with a 50 Ohm resistor. The capacitor suppresses an arc when the power switch opens and prevents a "pop" in the amplifier. The resistor limits the discharge current when the switch closes preventing the switch contacts from welding. If you can't find a similar unit, you can replace it with a capacitor and resistor in series.
Jim Mueller
PostPosted: Mar Wed 15, 2017 1:44 pm
Thanks Jim. I had a feeling this was the case. I recently ran into these capacitor-resistor combos in a Philco radio.
I'll just plan to install a cap and a resistor.
Joe Y.
PostPosted: Mar Wed 15, 2017 4:40 pm
I believe that arrangement of capacitor and resistor is commonly known as a "snubber", and as Jim noted, is for arc suppression. I'd leave it as is, unless you are getting a "pop" when the switch actuates...it's not doing any signal shaping.
PostPosted: Mar Wed 11, 2020 2:48 pm
What would be a suitable resistor wattage capacity value for this circuit?
PostPosted: Mar Tue 17, 2020 8:06 am
If it is not doing what it should the contacts on the shutoff will be
arcing.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
