It is currently Jan Sat 18, 2020 4:32 pm
 Post subject: Micronta 22-123 Variable DC Supply Schematic and PL
PostPosted: May Sat 20, 2017 6:53 am
I have one of these 0-24 V, 1A supplies that I got from a junk shop 10 or more years ago. I don't have a schematic or PL and need to replace the voltage adjust pot (which seems to have been previously replaced with and audio taper one). I can wing it but it would be helpful to have the maker data.
Does anyone have a schematic and PL they would like to share?
RRM
 Post subject: Re: Micronta 22-123 Variable DC Supply Schematic and PL
PostPosted: May Sat 20, 2017 1:26 pm
What is a PL ?
PostPosted: May Sat 20, 2017 1:52 pm
Parts List I assume.
Joel Walker
PostPosted: May Sat 20, 2017 3:00 pm
Only a guess here, but if it's based around the LM317T adjustable voltage regulator, the adjust pot would be 5k ohms, linear taper rated at 1/2 watt.
http://www.st.com/content/ccc/resource/ ... 000455.pdf
PostPosted: May Sat 20, 2017 9:16 pm
I found the manual for the "deluxe" model, 22-121
This model used the popular uA 723 / LM723 regulator.
https://elektrotanya.com/micronta_no.22 ... nload.html
Since Radio Shack often imported these from Taiwan you may find an op-amp" regulator circuit.
Later models incorporated the USA favorite, LM723 IC or as noted the LM317T series.
Micronta 22-123 Variable DC Supply.
File comment: Micronta 22-123
0 – 24 Volt, 2 Amp Bench Top Power Supply
DIY Project at Makezine.com : Uses the LM317T regulator.
Build a power supply from scratch.
by Michael Colombo
http://makezine.com/projects/0-24-volt- ... er-supply/
PostPosted: May Sat 20, 2017 11:20 pm
I have one of these and I'm sure I have the schematic, I'll see if I can find it tomorrow.
PostPosted: May Sun 21, 2017 1:18 am
Thanks Lou, that would be great.
I looked inside and mine uses an LM723 and has a 5K linear pot for the voltage adjust. The reason I though the pot might not be stock is that the voltage adjust is non-linear. The output doesn't get to 5V until the pot is almost half way up and 10 V is about 2/3 of the way to max (24V). Other than that it seems to work fine overall and all the tweaks work.
The thing was so dirty and rusty I almost passed it up but it was cheap (maybe $5). I wound up throwing the cover away and making one from plywood. It's been handy.
RRM
PostPosted: May Wed 24, 2017 1:39 am
Just a note. Even though everything seems ok now I'd still like to find a schematic and parts list if anyone has one.
RRM
PostPosted: May Wed 24, 2017 1:08 pm
Sorry RRM, my unit is a 22-126 and uses discrete transistors and zeners instead of a chip.
PostPosted: May Wed 24, 2017 10:55 pm
Thanks for looking, Lou. Looks like I need to get up the energy to trace the thing out and draw up a schematic.
RRM
PostPosted: May Thu 25, 2017 4:31 am
Greetings to Lou and the Forum:
I used to have a 22-126; I just sold it at a garage sale.... too many low voltage supplies cluttering up the place. However, I did have to repair it when I got it and did reverse engineer it. If you would like the schematic, here it is:
Micronta Power Supply 22-126.pdf [52.01 KiB]
Downloaded 121 times
Jim T.
KB6GM
PostPosted: May Thu 25, 2017 11:33 pm
Thanks Jim, I do have the original manual for mine.
PostPosted: May Fri 26, 2017 1:04 am
Is the negative terminal really connected to the chassis? That limits it's usefulness somewhat, especially for older PNP transistor radios.
Cheers - Martin ZL2MC
PostPosted: May Fri 26, 2017 1:49 am
Greetings to Marty and the Forum:
I believe the upside down non-filled arrowhead or triangle symbol that I used in the drawing refers to circuit ground, not chassis ground.
Jim T.
KB6GM
PostPosted: Mar Fri 09, 2018 10:10 pm
If you still need this info, the voltage pot has the following markings on it: 1377702 996-0057
Users browsing this forum: stevebyan and 10 guests
