It is currently Jun Thu 04, 2020 5:19 am
Post New Topic Post Reply  [ 269 posts ]  Go to page 1, 2, 3, 4, 5 ... 14  Next
 Post subject: Philco amp re-build.
PostPosted: Aug Sun 20, 2017 10:08 pm
I have two Philco amps to re-build. Thank you Peter. Model no. SA-1000.
download/file.php?id=187445
John Smith, over and out.
 Post subject: Re: Philco amp re-build.
PostPosted: Aug Sun 20, 2017 10:21 pm
I was thinking that since I will need the 8 ohm tap for the speaker, I t would be better to not connect the cathodes there. Just connect to ground. Don't know what that would do to the FB circuit. What do you suggest? How about A CCS?
PostPosted: Aug Sun 20, 2017 10:32 pm
Leave as designed... for now.
Then test and see how you like the sound.
first.
If you think it sounds good you can leave it that way and have it match the print.
If you want to modify it after you hear it.. sure we can go for the CCS and change the FB as I show in that colored schematic.
What "8 ohm tap" are you referring to?
The top tap?
I don't know if that's 8 ohms or whatever.
The schematic show a YEL lead for that connection to FB.
Does the paperwork list the partnumber for that transformer and does it show the specs?
I believe somewhere it does.
---- maybe this is it? ----
The actual OT is a Philco #32-8849-1
4300 ohm CT primary
9 ohm secondary ( tap=3-4ohm)
PostPosted: Aug Sun 20, 2017 11:31 pm
That's correct Peter. Looks like it was for a 4ohm speaker. CCS, a definite possibility, later. I do still have the 4ohm speakers from the Zenith console. Might be a good match.
OK. I will follow same schematic. I Like your idea. Will also document with photos.
PostPosted: Aug Sun 20, 2017 11:35 pm
Why do you say "it looks like it was for a 4 ohm speaker"? Based on What???
The data I showed you above for the OT part number shows 9 ohm... right?
PostPosted: Aug Mon 21, 2017 1:39 am
Don't change anything till you understand the circuit and what things do.
The cathodes connect there because the OPT secondary feedback makes the cathode self split approach something akin to being 'balanced'. Without it the circuit is positively dismal.
PostPosted: Aug Mon 21, 2017 2:36 am
Thanks Flip. You and Peter both agree. That's good enough for me.
PostPosted: Aug Mon 21, 2017 2:43 am
I stripped the chassis of all components. Everything will be modern, except the transformers. One pin on a tube socket broke off, so I replaced it and noticed that the new sockets look better that the old ones. So I replaced them all.
One chassis shows before I touched it. The other one is ready for rewiring.
PostPosted: Aug Mon 21, 2017 3:31 am
I believe the posted schematic is incomplete. Here's the full version.
PostPosted: Aug Mon 21, 2017 4:04 am
Correct Flip. I am not interested in the outside connections.
PostPosted: Aug Mon 21, 2017 4:19 am
I know but yours has none of the tone controls.
PostPosted: Aug Mon 21, 2017 5:04 am
WHAT
No tone controls :?:
That's like a day without sunshine.
That must be fixed right now.
Thanks :!:
PostPosted: Aug Mon 21, 2017 6:23 am
What do you mean?
I sent John two amps... 1606 and SA1000
Both had tone all the control knobs and circuits matching the print..
PostPosted: Aug Mon 21, 2017 6:24 am
john8750 wrote:
WHAT
Thanks :!:
Someone apparently thought they were 'removing' the tone controls but they didn't get it all. The .01 cap in series with the feedback is there to reduce feedback in the bass region so, effectively, it's boosted relative to the rest. That provides the range for the bass control. I.e. when full up it's like the first circuit. Half way it cuts the bass down to the same level as the rest and, of course, the other half is cut below. That's the primary purpose of the negative feedback and any 'distortion reduction' would an ancillary side effect.
The treble control is rather common for low end amplifiers except for having to 'fight' the meager feedback, which tries to compensate for the frequency shift (that's what negative feedback does), but it soon overwhelms feedback and then works as normal.
PostPosted: Aug Mon 21, 2017 6:25 am
What do you mean?
I sent John two amps... 1606 and 1005
I mean the schematic he posted at the beginning of this thread doesn't have the tone controls.
PostPosted: Aug Mon 21, 2017 6:29 am
I explained all that to him already Flip and advised him not to change the layout until he has it ALL working and he can hear how the original design was intended to sound first.
Thing is.. he does not have the electrostatic tweeters.
PostPosted: Aug Mon 21, 2017 6:32 am
John:
If you haven't stripped both amps yet. I'd leave one original to follow in case you have layout questions later.
Also, sometimes it's easier to replace the old components in the same location one at a time as you go along instead of pulling everything out at once.
... but these are not too complicated.
PostPosted: Aug Mon 21, 2017 6:36 am
I just looked at that schematic he posted :
http://www.antiqueradios.com/forums/dow ... ?id=187445
and I see the tone controls on the left side of the print.
PostPosted: Aug Mon 21, 2017 6:40 am
I just looked at that schematic he posted and I see the tone controls on the left side of the print.
Must be in invisible ink, then, because the one I see in the very first post, titled philco%20sa1000-amp[1].png, has no tone controls at all.
PostPosted: Aug Mon 21, 2017 6:42 am
I'm looking at the link print:
Yes the other one is something I think I made up 4 years ago.. maybe I cut stuff out... lol
