It is currently Oct Sat 24, 2020 4:51 am
Post New Topic Post Reply  [ 269 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13, 14  Next
PostPosted: Sep Sun 17, 2017 10:34 pm
john8750 wrote:
Here is a photo of the heater. Just ready for a re-sealing for the winter. The summer sun is brutal.
The youtube video shows the black-screen version puts out more heat than the tin-can version by about 5 degrees... and simpler to build.
https://www.youtube.com/watch?v=PyVPNOUpOVg
PostPosted: Sep Sun 17, 2017 10:44 pm
He did not build the heater properly. Look at the can heater. He has no solar reflector behind the cans, and no sealed plenum, return and supply. my heater has run at 183F. How long did he run his?
John Smith, over and out.
PostPosted: Sep Sun 17, 2017 10:50 pm
Hey... don't beat me up.... lol .... I just showed you the video... lol
PostPosted: Sep Sun 17, 2017 11:07 pm
Its show time boys and boys.
I cleaned off my work bench. Then connected both Philco amps to the test speakers.
Plugged them in. The first amp works good. The second amp did not work at all.
Swapped speakers, same, swapped all tubes, same.
AC voltages were close enough on the input, and up to the preamp tube.
I checked all connections, good. OT connections. Coupling caps, good.
Then did a signal check from the preamp tube forward, found the problem.
C6, .047 coupling cap. Pin5 of the preamp tube, 6AU6 had a small bouncing AC
signal. Input to the 6AQ5, pin1 had no signal. Bad cap?
Then I decided to check the resistance of the grid leak, R8, 470K.
Read 470ohms! I had installed the wrong size resistor.
So I replaced it and, that made the thing work.
They both work pretty good.
And, the test speakers are totally acceptable, good bass and treble control,
although they only cut and cannot boost, still do work.
I could enjoy listening to these while working at the bench.
I know you wont believe me Peter, so just get on the train and come out
here to hear them yourself. we'll leave the light on for ya :lol:
PostPosted: Sep Sun 17, 2017 11:13 pm
This is me and my Cousin. I was about 5 or so.
BTW- I am the boy.
Who would of thought that he would turn out to be a Genius?
PostPosted: Sep Sun 17, 2017 11:20 pm
BTW- I am the boy.
i thought you were the liitle blonde and maybe still transitioning with all the sex change operations.
PostPosted: Sep Sun 17, 2017 11:24 pm
Hi John:
Looking good.
Very glad these little gifts are in your hands where you are having fun using them instead of still sitting in a box on my repair shelf.
Good on ya!
I thought you said you were going to check EVERY resistor on your new component testing thingie?
This is why I suggested to mark your resistor storage envelopes with the correct colors too so as to avoid making these mistakes.
I had the SAME problem with these 1% 4-band lousy color code resistors.
As for the dual amp inputs... if it were me.. I'd want to combine the inputs to one single vol control and such.
PostPosted: Sep Sun 17, 2017 11:44 pm
Hi John:
Looking good.
Good on ya!
Thanks again Peter. Oh what a thrill it is to have them.
I had already bought and received resistors for these amps separately. My meter is auto ranging, I don't like it for this reason. In the top right corner of the display, is a very small designating emblem to show either an ohm, K, or M. So using my old eyes, I saw the wrong emblem.
And there is no way I can figure out those 4 or 5 band resistors. You need squinty eyes for that.
You know how I like vintage stuff. Just wouldn't be the same if I remodeled for one volume control.
PostPosted: Sep Mon 18, 2017 12:21 am
Hi John:
Looking good.
Good on ya!
Hi vintage John:
Well if you think about.. these amps were never designed as a stereo-amp the way you are using them They came out of old mono-phonographs or such from the 50s or 60s I think.
So since you're sort-of modifying the original idea anyway... you could just add a little outboard vol control and wire it over to each input preset-cranked up to max. But if you don't mind trying to get each channel vol balanced... enjoy them as is.
Have fun buddy. Thanks for giving them new life.
PostPosted: Sep Mon 18, 2017 3:58 am
And thank you peter. A few times now you have helped me greatly.
Now to mount both amps on a nice frame and set it on top of the Zenith.
It will be used for my listening pleasures while in the shop.
BTW- the amps must of had a low level input, like a crystal stylus.
The MP3 has plenty of volume.
PostPosted: Sep Mon 18, 2017 5:54 am
But now you have downward facing music... will this depress you?
PostPosted: Sep Mon 18, 2017 7:33 am
I had wondered how that would sound. Seems to sound good. Different though.
Why would that depress me?
The tone controls are both responsive, and work good. I am impressed with the amps and speakers.
They seem to be a good match. Next will be to try the amps with the Zenith.
PostPosted: Sep Mon 18, 2017 9:17 am
Sound is pressing downward upon your hillbilly brain.
PostPosted: Sep Mon 18, 2017 5:13 pm
Does it sound good enough to where the bass channel is not needed?
PostPosted: Sep Mon 18, 2017 7:30 pm
My brain was shot long ago. At about seven, on my grampas farm in New Mexico. He had a bull.
PostPosted: Sep Mon 18, 2017 7:36 pm
Yes, it has plenty of bass now. Can tell better after connection to the Zenith.
When I tested the first amp, it was connected to a speaker just laying on the bench,
no enclosure. Now the speakers are enclosed with some padding in the back.
Sounds very good.
Much appreciate your work. Would like to see that Magnavox subwoofer amp schematic.
Unless it is the same one I already have.
PostPosted: Sep Mon 18, 2017 8:45 pm
It's the Motorola schematic.
I still have it.
I'll look today and see if it is completed and if so I'll email it to you.
PostPosted: Sep Mon 18, 2017 8:53 pm
I still have it.
Thanks Justin. I have it somewhere also. But to find it :?:
PostPosted: Sep Mon 18, 2017 8:59 pm
You're welcome.
PostPosted: Sep Mon 18, 2017 9:04 pm
Tube Radio wrote:
You're welcome.
I found it. From Motorola, it must be good....
