It is currently Oct Sat 16, 2021 8:25 pm
 Post subject: Atwater Kent Model 10
PostPosted: Mar Sat 12, 2005 5:06 pm
If one were to purchase a AK model 10 is there one model that would be prefered over the others? If so what would the advantages be?<BR>Thanks, Jim<P>------------------<BR>
PostPosted: Mar Sat 12, 2005 5:16 pm
Hi Jim,<P>There are seven versions of the Model 10:<P>10 4340 Radiodyne: the original version, rather rare<BR>10 4340 non-Radiodyne<BR>10A 4550: brown or gray/green paint<BR>10A 4560: black paint<BR>10B 4550: brown or gray/green paint<BR>10B 4560: black paint<BR>10C 4700<P>The four-digit number is the catalog number, which is on the tag on the bottom.<P>There's also a Model 12 4620 or 4910 which you might want to add to your list. It's like the Model 10 but with an additional audio stage.<P>You'll find pictures of all of these in the Gallery on my AK site.<P>You might want to post your question on the ISAKC board at <A HREF="http://www.AtwaterKent.com/forums" TARGET=_blank>http://www.AtwaterKent.com/forums</A> .<P>One word of caution: These are expensive radios, and there are a lot of undesirables out there. Repro parts and/or boards, radios built up from miscellaneous parts, reworks and outright fakes. I suggest you solicit learned opinions on any particular set that you consider.<P>------------------<BR>73 de Leigh W3NLB | | Leigh@AtwaterKent.Info<BR><A HREF="http://www.AtwaterKent.info" TARGET=_blank>http://www.AtwaterKent.info</A> | | <A HREF="http://www.Synchrophase.info" TARGET=_blank>http://www.Synchrophase.info</A>
PostPosted: Mar Sat 12, 2005 6:38 pm
Hi Leigh,<BR>Thanks for informative post.<BR>Jim<P>------------------<BR>
Post New Topic Post Reply  [ 3 posts ]  Moderator: sofaslug
Users browsing this forum: JerryHawthorne, joekpayne, Merrill Bancroft and 65 guests
