It is currently Aug Sun 25, 2019 3:41 am
Post New Topic Post Reply  [ 94 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Scored an Admiral 19A11
PostPosted: Dec Thu 28, 2017 2:07 am
Crist Rigotti wrote:
I'm going to add the retrace blanking circuit that Phil shows on his website. It shows a 250pf 1Kv cap and a 22K resistor. What type of cap should I use? A ceramic, mica, other?
https://antiqueradio.org/Admiral19A12Television.htm
I'd probably go with mica, although I think 270 pF is a more common value. Ceramic would be OK too.
Tim
PostPosted: Dec Fri 29, 2017 1:41 am
Best to go with a 1 kV voltage rating on that cap. I usually use ceramic, since I have a bunch of those, but 1000 V micas should be OK. Plate voltage can be quite high on vertical output tube, if that’s where you’re grabbing the signal.
Tom K6VL
PostPosted: Dec Fri 29, 2017 7:03 am
Yeah, I did get some 1Kv caps for that circuit.
I've ordered the HV caps, 630V caps, and picked the other stuff up from Mouser. They are only a 20 minute drive away! Will Call so there is no shipping. :D
Working on stuffing the 3 section E-Cap C1. Pics to follow.
Crist
PostPosted: Dec Fri 29, 2017 6:25 pm
Wow! Am I ever jealous of you!
PostPosted: Jan Fri 05, 2018 3:53 am
Been busy over the holiday. Things have settled down a bit.
File comment: I re-stuffed C1 with 3 Nichicon 10k hour caps in the usual manner that I do.
File comment: Then I labeled all the components like I usually do.
File comment: I noticed that the 3 wires coming from the HV coil going to the Osc. 6V6 tube were hard and the insulation just crumbled away. So I'm in the middle of replacing those wires along with the HV wire going to the plate cap of the 1B3GT. That wire was cracking too.
Crist
PostPosted: Jan Mon 08, 2018 6:53 am
An update of my progress. The HV caps came in so I started with the HV section. I replaced all the caps and resistors, and thouroughly cleaned all surfaces. I removed the phenolic board and pots and cleaned them too.
File comment: I then installed a fuse holder in the AC line going to the ON/OFF switch. I used an existing holes and just removed the wire from the interlock and folded it back to the fuse holder and installed a new brown wire from the fuse holder to the interlock.
File comment: I then installed C1 and wired that.
File comment: Then C2 was replaced with a terminal strip and 2 E-Caps. The ground terminal was soldered to the chassis like all ground terminals are. The terminal strip was placed in the same location as the clip was for C2. The wires were then just tacked in place so I could do a power up.
Crist
PostPosted: Jan Mon 08, 2018 8:39 pm
With the lovely work you are doing that TV is going to be better than new when you're done.
Mark Nelson
tv-boxes.com
PostPosted: Jan Mon 08, 2018 11:29 pm
Awesome work! How do you get the chassis of a 70 year old set to look like it's new?
PostPosted: Jan Tue 09, 2018 2:40 am
Thank you Mark.
Crist
PostPosted: Jan Tue 09, 2018 2:42 am
I scrub the outside with 50/50 CLR and water using a soft brass bristle brush from Harbor Freight. On the inside I use a cut down acid brush and acetone. Then some Q-Tips to get into the crevices.
Crist
PostPosted: Jan Tue 09, 2018 2:44 am
I'm replacing the components in the Horizontal and Vertical sections right now. I thought that I would include a picture of how I arrange things when I'm doing a section of the chassis.
First thing I do is take some close up pictures of the area. Then using some lined notebook paper and a pencil, I draw out what is connected. For example let's say a tube we'll call V12. I draw a circle and place the key way and 8 dots which represent the terminals. I then draw a resistor going from pin 1 and the other end of the resistor I list where it goes like #3 V13, and so on. I also draw in what ever is connected to that terminal like wires, coils, etc.
Then I clip out the components that I'll be changing out. I lay then next to the chassis then I measure the resistance of the clipped out resistors and record them on my spreadsheet. I then get a new resistor and measure that and again record it on my spreadsheet. I dig out the the new caps too. I placed the new components next to the old ones. I then clean up the terminals and clean them using an acid brush and acetone. I then make any repairs needed to wiring etc.
Then I start to install the new components. It's like building a kit now! After soldering, I again clean the terminals with acetone.
Then take a break.
Crist
PostPosted: Jan Tue 09, 2018 2:54 pm
The Horizontal and Vertical sections are finished. Today I'll power it up and see my progress.
Crist
PostPosted: Jan Tue 09, 2018 11:07 pm
I did the audio section today. Here are the before and after pictures.
Crist
PostPosted: Jan Tue 09, 2018 11:18 pm
Nice Neat work !
you even cleaned off the old Flux, after power up will you be aligning the I.F stages?
Terry
PostPosted: Jan Tue 09, 2018 11:31 pm
Nice Neat work !
Terry
Thank you.
Yes, I'll align the IF stages and audio.
Crist
PostPosted: Jan Thu 11, 2018 4:57 am
Today I worked backward through V9 the Ratio Detector, V8 the sound IF, V7 the Video Amp, V6 the video detector, V5 the 3rd Video IF, and V4 the 2nd Video IF. All that's left is V3 the 1st Video IF and the Tuner.
Crist
PostPosted: Jan Thu 11, 2018 4:58 am
BTW, I got a original Sams Photofact for this TV. It's Sams 59-2. I scanned it and sent Steve at ETF a compressed pdf copy that is much better than what's up there now. Looks like Steve did some further compression and the copy isn't all that good.
Never fear. I've uploaded the full resolution pdf in my dropbox. You can enlarged it at least 400X and it is still very readable. Here's the link. Caution large file @16Mb.
https://www.dropbox.com/s/o0f1yge36vw1h ... 2.pdf?dl=0
Crist
PostPosted: Jan Thu 11, 2018 5:13 pm
OK, I have a concern that I need cleared up. There are these ceramic capacitors used in this TV, mostly in the IF stages. I call them "Hot Dog" caps because they look like hot dogs. Seeing they are ceramic I haven't paid too much attention to them when I do a recap. On this chassis I'm down to the last tube, tube V3, and decided to check some of these caps because they were already disconnected while I'm replacing the resistors. Well, to my amazement the 5 I checked were well out of tolerance......I think.
According to the the Sams parts list, C12-C16 (the ones I checked) can use Aerovox 1468, Cornell-Dubilier 1W series which both are mica caps. I looked in the 1951 Allied catalog and the C-D mica caps have a tolerance of +/- 20% while there was no tolerance listed in the Allied catalog for the Aerovox caps.
In the picture of the schematic below I have penciled in the readings I get for each capacitor. They are:
C12 - 1623pf
C13 - 1431pf
C14 - 1931pf
C15 - 1707pf
C16 - 1230pf
Should I check all of those hot dog caps and replace them too? I've never replaced those before because I've always thought they were good. Now I'm not so sure.
Crist
PostPosted: Jan Thu 11, 2018 5:26 pm
Since those are all bypass caps, a capacitance that is a bit too high should be no problem. I'd leave them in place. I'm surprised they are out of tolerance -- I don't expect that from ceramic caps.
Have you confirmed that they are free of leakage current?
Tom K6VL
PostPosted: Jan Thu 11, 2018 5:51 pm
No I didn't check for leakage? How do I do that? Do I use my vintage Solar cap checker for that?
Crist
Post New Topic Post Reply  [ 94 posts ]  Moderators: 7jp4-guy, Mr. Detrola Go to page Previous  1, 2, 3, 4, 5  Next
