It is currently Jun Wed 19, 2019 4:42 am
 Post subject: Lafayette Receiver dial light bulbs--FIXED
PostPosted: Jan Tue 02, 2018 3:34 am
What would be a good substitute for this bulb? The originals are "8V .25A S" (Bayonet base)
 Post subject: Re: Lafayette Receiver dial light bulbs
PostPosted: Jan Tue 02, 2018 4:35 am
Most of the smaller bayonet 6V lamps were rated @ 6-8V.
A 12V would by fine if indeed you have 8V across the lamp.
DDG
Workin' my Gramophone in a smartphone world.
PostPosted: Jan Tue 02, 2018 4:42 am
I indeed measured 8V AC at the lamp socket. (no bulb in it)
PostPosted: Jan Tue 02, 2018 4:48 am
PM me with the bulb shape and your addy, I'd be glad to send you some.
PostPosted: Jan Tue 02, 2018 4:00 pm
This is what it looks like:
 Post subject: Re: Lafayette Receiver dial light bulbs--FIXED
PostPosted: Jan Thu 18, 2018 2:38 am
Couldn't come up with a bulb, so I improvised. Used a #46 bulb and converted it from a screw-in base to a bayonet base by soldering pieces of wire (donated from the ends of a resistor) in to create the "bayonet". Added a 5ohm resistor to drop the 8V filament voltage down to around 6V. Works great.
PostPosted: Jan Thu 18, 2018 2:47 am
Hmmm...I mailed you a lifetime supply---no gottum?
PostPosted: Jan Thu 18, 2018 5:27 am
Nope. USPS?
PostPosted: Jan Thu 18, 2018 5:33 am
Yep.
