It is currently Jul Sun 05, 2020 10:29 am
 Post subject: What makes a good 1629 magic eye suddenly stop glowing?
PostPosted: Jan Mon 29, 2018 5:39 am
I had a real good 1629 in my Eico 950b cap checker. something popped inside the tube, and the green was gone. the filament was still lit. im assuming it was a failure in the tube and not something in the tester, as it was working fine.
Ugh. the other ones i have are dim to needing to be used in a dark room to see,
Tony Pignaloni
 Post subject: Re: What makes a good 1629 magic eye suddenly stop glowing?
PostPosted: Jan Mon 29, 2018 5:43 am
What other symptoms do you have?
I never heard of a tube making a noise when it failed.
I'm thinking you probably blew an electrolytic filter cap.
PostPosted: Jan Mon 29, 2018 5:57 am
Agree with Leigh. Look for B+ voltage on pin #4 of the 1629. Should be near 250 volts.
PostPosted: Jan Mon 29, 2018 6:03 am
ok. ill check. but ill add i just got done recapping the unit, and it was working fine. not that any one of the new caps might have gone bad.
Tony Pignaloni
PostPosted: Jan Mon 29, 2018 10:58 am
I recommend resoldering all the pins.
PostPosted: Jan Mon 29, 2018 11:18 am
I do have plate voltage.
this is what i think happened. the end of the Voltage pot is grounded to chassis via a lug under the shaft bushing on my other Eico 950. on the unit in question, the grounded terminal is hardwired to chassis ground using a ground terminal on the rectifier tube socket. well. i think maybe the capacitor discharge of turning the voltage pot down of a cap under test backfed to the plate lead of the 1629. bcause there is the plate lead to the 1629, then via ground to a resisistor. A ground lug on the rectifier socket made a convienent ground. im going to change it to a ground lug under the voltage pot bushing to chassis ike the other one. im guessing someone may have lost the ground lug.
Tony Pignaloni
