Page 1 of 1
[ 7 posts ] |
Author |
hookemdevils22
Post subject: Philco 51-1731 Restoration Posted: Jan Mon 29, 2018 4:42 am |
Top |
Tom Albrecht
Post subject: Re: Philco 51-1731 Restoration Posted: Jan Mon 29, 2018 8:55 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 11988 Location: San Jose, CA USA
The radio chassis needs its electrolytic and paper capacitors replaced as well as checking the tubes. See here for advice on how to go about that: https://www.antiqueradio.org/begin.htmWhat is broken on the turntable? It may be repairable.
_________________ Tom K6VL
Top |
hookemdevils22
Post subject: Re: Philco 51-1731 Restoration Posted: Feb Thu 01, 2018 10:10 pm |
The tone arm is broken and the spindle is bent, as shown in the last photo. I'll pull the chassis and locate the caps before buying tubes, and thanks for the guidance.
Top |
Tom Albrecht
Post subject: Re: Philco 51-1731 Restoration Posted: Feb Thu 01, 2018 11:38 pm |
Member |
The spindle might be OK -- they are made with a bent shape like that. But indeed, your tone arm looks a bit distressed! You may be able to find a replacement tone arm or the whole record changer assembly if you place a want ad in the classified section here.
Did you take a stab at replacing capacitors yet? Tubes are often still good, so you may not need to buy any replacements for those.
Top |
egg
Post subject: Re: Philco 51-1731 Restoration Posted: Feb Fri 02, 2018 12:32 am |
Member |
Joined: Jan Tue 31, 2012 1:55 am Posts: 15265 Location: Mountains of Mourne. Ireland.
Top |
paul.demming
Post subject: Re: Philco 51-1731 Restoration Posted: Feb Fri 09, 2018 3:03 pm |
Joined: Apr Thu 13, 2017 11:22 pm Posts: 73 Location: Cleveland, Ohio 44102
i just finished a unit exactly like this. took me 3 months. The phonograph is a real bear. you can get the belt and drive wheel and needle. the crystal cartridge on the other hand, I'm still looking, pray yours is good. Forget the Sam's Photofact for this set, it is useless. the Philco manual is golden. Steve Johnson schematics has it. sorry i don't have the link. As for the radio, there are several capacitors that YOU CANNOT REPLACE. you will mess up your whole world. they look like resistors, but they are in fact capacitors. Also, there are wire wound caps, wax coated. Do Not change those either. Do replace the wax paper caps and the black caps with multiple stripes and the filter caps. Also put some machine oil down the holes top and bottom of all your IF transformers several times to loosen them up. The cores on these are made of fired clay and have a straight slot in them. They seize up, and when you try to align, they break. its a nightmare. Feel free to message me if you are going to tackle this radio and have questions. i just delivered it last week and it is pretty fresh in my little brain.
Top |
Easca6768
Post subject: Re: Philco 51-1731 Restoration Posted: Nov Sun 08, 2020 9:09 pm |
I have the same model but I am unable to find the needle. Do you know what kind of needle it takes?
Top |
